Pre 84 Trucks 1st gen pickups
Compatable Seats for 1st Gen
Old Dec 13, 2008 | 02:08 AM
"Master Yoda"'s Avatar
My seats are ragged and my budget doesnt hold enough for some suspension seats right now. Just wondering if anyone knows what other style, comfertable, seats that will bolt up to my '81 yoda. thanks for the help.
Old Dec 13, 2008 | 02:49 AM
dropzone's Avatar
Fossilized
not a total direct bolt in but here is what I did:
Found a set of 93-94 Integra seats that were a little dirty but overall excellant shape:
Originally Posted by ocdropzone
Finally had a little time to get my Integra seats installed.
These things are great, there is a second hole about 1.25" over from the stock front outside mounting hole that lined up just about right, enlarged it just a hair and was able to use the inside front stock mount:
just had to cut off about the lower .25" or so of the stock bracket to allow it to sit flat on the floor.
I think that being able to use the stock front holes makes the install much more stable and install went very fast...
outside rear mount came up with something similar to WSUWeston's brackets:
The rear inside mount is flat, so ended up using the old stack of washers install method. Used grade 8 fender washers on the underside so that should help spread the load.
other seats that work well are early 90's Civic
Old Dec 13, 2008 | 07:51 AM
integra seats
so i can use both stock front holes i just have to make some simple rear brackets for them to work? how do they fit in the cab as far as room?
Old Dec 13, 2008 | 08:22 AM
scooper's Avatar
I have the same seat in mine, haha.
You will LOVE these seats. They fit like glove and only sit a hair higher than the stock ones.
My truck came with a bench seat, that was the first thing to go. I went to the boneyard and gave 50 bucks for the seats out of a 94 integra and put them in and absolutely loved them. Then i found a set of SR5 bucket seats at another junkyard, gave 75 bucks for the set, installed them, and rode with them for less than a week before i took them out and put he integra seats back in.
ghostmoney
Aug 6, 2015 08:40 AM
vanion2
Jul 29, 2015 06:17 PM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
