Pre 84 Trucks 1st gen pickups
Straight line struggles
Old Apr 12, 2014 | 10:48 AM
PAgrown's Avatar
Alright so I took my toyota on its first highway drive yesterday. It has power steering and 35s. Whenever the road would be slightly uneven it'd pull HARD to that side. Later last night at home I was playing with the steering wheel and it just starts moving back and forth about two inches each wiggle with the truck at a stand still and my hands off the wheel. Sure scared the hell out of people swerving all over a 50mph
Old Apr 12, 2014 | 04:56 PM
ksti's Avatar
How long have the 35's been on it and did you check your steering stabilizer?
Old Apr 12, 2014 | 06:06 PM
gillesdetrail's Avatar
Make sure there is no slack in the steering box, if there is, it is adjustable, but there is a proper way to adjust it without having issures (as you know steering issues on the road is the last thing you want), make sure you don't have loose in the steering column u-joint, steering box u-joint, tie-rod ends and as mentioned above steering stabiliser.
Old Apr 12, 2014 | 06:36 PM
kawazx636's Avatar
First check your drag link for play, then steering stabilizer and then the worm gear adjustment.
Old Apr 12, 2014 | 08:07 PM
81yodar's Avatar
I had the same problem with my truck, turns out that the front shims where on backwards and the tie rod ends where bad. But the shims really screwed it up. The thick end needs to be facing towards the rear.
Eggslinger
Jun 8, 2019 03:32 PM
4x4-runner
Apr 18, 2017 09:08 PM
Up&Down
Aug 5, 2015 06:20 AM
cgilley
Jul 25, 2015 10:55 PM
yourrealdad
Jul 21, 2015 11:13 AM
