Pre 84 Trucks 1st gen pickups
wiring help
Old Apr 26, 2014 | 04:04 PM
83yotastockR's Avatar
wiring help
So I have a 1983 pickup with a 1980 wiring harness the truck has been apart for multiple years finally put the rebuilt engine in well I can't seem to get power from the battery to the truck. Anyone have pictures of how the battery cables are where they mount and what I could have done wrong??? I know cables are good they are brand new grounds and battery are both clean and battery is charged.wiring diagrams don't help because they don't tell you where the ground wire goes.please help
Old Apr 26, 2014 | 04:54 PM
Anyone
Old Apr 26, 2014 | 05:00 PM
JasonYota's Avatar
Ground wire from your battery can go to the engine block or the frame.
Old Apr 26, 2014 | 05:02 PM
Tryed both spots and no luck even made sure it was bare metal since I coated the frame
Old Apr 26, 2014 | 05:08 PM
JasonYota's Avatar
Then the problem is on the positive side. Your not getting power to your fuse block? What exactly is the problem your having?
Old Apr 26, 2014 | 05:20 PM
slacker's Avatar
if it's stock wiring .. there are "fuse links" right off of the positive post clamp . check to see if these are ok
Old Apr 26, 2014 | 05:38 PM
Not stock wiring the diagram shows the red battery cable going to the starter? There is a black with white stripe that goes to the starter also. I have the ground wire to the engine.
Old Apr 26, 2014 | 05:40 PM
I think pictures would help if anyone could get me pictures on how there's is wired.
Old Apr 26, 2014 | 05:48 PM
JasonYota's Avatar
The main red(power) wire goes to the starter. You should also have another power wire going to the fuses. The black w/ white stripe is your trigger that actually engages the starter motor.
Old Apr 26, 2014 | 05:51 PM
OK where does that hook into the harness at diagram shows nothing
Old Apr 26, 2014 | 05:53 PM
JasonYota's Avatar
It should go to your ignition switch, probably through a couple of harness connectors though.
Old Apr 27, 2014 | 05:39 PM
Figured it out one of the small wires were broke thanks but now no spark from the coil checked everything ohms and voltage but no spark going to the distributor. I'm going to post another thread to explain more in depth
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
