Pre 84 Trucks 1st gen pickups
Dies at idle
Old Sep 30, 2014 | 10:24 AM
Juhjuhjinx's Avatar
Dies at idle
my 83 22r pickup runs great but every once in a while it won't idle.
It will keep shutting its self off if I'm not holding the gas...
Suggestions??
Thanks!
Also it fires up and fires back up without hesitation
Old Sep 30, 2014 | 03:45 PM
enigmaT120's Avatar
What carb, stock?
Old Sep 30, 2014 | 03:50 PM
Juhjuhjinx's Avatar
Yes I'm pretty sure its stock
I don't know much about it, I just got it
Also it isles at around 1.1k
Is that normal?
Old Sep 30, 2014 | 03:52 PM
Kiroshu's Avatar
Welcome to YotaTech!
More information on this complaint would be helpful.
Any other symptoms from the vehicle at all..?
Any work performed recently...?
Tampering..?
Any smoke from tail pipe while poor idle speed occurs..?
Check for intake/vacuum leaks.
Intake air restrictions..?
Air filter dirty..?
Fuel system performance/leaks/damage..?
Incorrect idle speed/incorrect ignition timing..?
Carburetor faulty/incorrect adjustments..?
Fuel mixture..?
Engine accessories failing dragging the engine...?
Old Sep 30, 2014 | 04:35 PM
Juhjuhjinx's Avatar
Tampering..?
Air filter dirty..?
Fuel mixture..?
I literally just got it less than a week ago. I haven't done any work on it. The air filter is good, it has the stock air intake. (Considering a cold air)
There are no vacuum, intake, or any leaks. Other than a small oil leak. But that wouldn't cause it.
I don't know much about fuel mixture or carbs or adjustments for them. But it idles at 1.1k which seems high to me.
Sorry to be so blunt. I don't know much about toyotas or carbed vehicles
Old Oct 12, 2014 | 11:15 AM
5440's Avatar
Fuel cut solenoid.
Old Oct 12, 2014 | 11:16 AM
Juhjuhjinx's Avatar
Originally Posted by 5440
Fuel cut solenoid.
What do you mean?
Charecter1
Nov 6, 2023 10:08 AM
Phantez
Oct 30, 2015 04:46 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
kyletbert
Jul 17, 2015 11:39 AM
