Pre 84 Trucks 1st gen pickups
Fan shroud label...
Old Jul 25, 2014 | 03:09 PM
81 Toyo's Avatar
Fan shroud label...
Can someone tell me what's on the yellow label on the fan shroud?......my labels are there but the text is long gone.......would like to find repos if available. Thanks
Old Jul 25, 2014 | 08:21 PM
kawazx636's Avatar
It says "Place hand below when engine is running" LOL
I've never seen one but I imagine it is some sort of safety warning about the fan.
Old Jul 26, 2014 | 03:53 AM
81 Toyo's Avatar
Originally Posted by kawazx636
It says "Place hand below when engine is running" .
There's a comedian in every crowd!....haha...
Old Jul 26, 2014 | 04:26 PM
slacker's Avatar
could it be this
I have been looking for a good "candidate" for a while , as well as the one on the overflow tank
Old Jul 27, 2014 | 05:44 AM
gillesdetrail's Avatar
I don't think you can see it in this pic, but it might be useful in a way!
Last edited by rworegon; Jul 27, 2014 at 12:43 PM. Reason: Removed unfamily friendly text.
Old Aug 2, 2014 | 12:17 PM
1st Gen Crawler's Avatar
^ That is one pretty looking engine bay. Gilles, have you rebuild everything, or just kept it beautiful for all of these years?
Old Aug 2, 2014 | 01:57 PM
81 Toyo's Avatar
That looks like a brochure pic.....can you make out the yellow decal on the valve cover?
Old Aug 2, 2014 | 01:59 PM
81 Toyo's Avatar
Originally Posted by slacker
could it be this
My overflow tank decal is in good shape...will post a pic tommorow
Old Aug 2, 2014 | 02:02 PM
Danger, that is a Toyota's middle name.
Old Aug 2, 2014 | 11:12 PM
kawazx636's Avatar
I have to go check my pants.....
Old Aug 3, 2014 | 09:52 AM
81 Toyo's Avatar
[QUOTE=slacker;
.[/QUOTE]
See if this helps Slacker.....can't help you on the last line of Japanese..
Old Aug 3, 2014 | 12:30 PM
Haha that isn't my engine bay, I wish!
81toyo, from what I can see it says (the x is what I can't see)
CAUTION
use only API ''xx''
or better grade
engine oils
Old Aug 3, 2014 | 04:33 PM
slacker's Avatar
thanks .. that'll work !
Old Sep 14, 2014 | 06:26 AM
subaholic's Avatar
Fan shroud label
Hey 81Toyo, my '83 still has the label on the fan shroud. It gives instructions/cautions for adjusting the belt tension for the air pump....there is some text that instructs to pry on the rear cover, don't pry on the aluminum body. It also say's not to oil the pump. On the lower right there's a diagram of the pump with the correct and incorrect prying locations and where not to oil.
Does this help?
Old Sep 14, 2014 | 02:23 PM
81 Toyo's Avatar
Thanks guy......every one Ive seen is faded beyond legibility.....your engine bay must be in nice shape for that label to have survived.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
runnermedic
13
Sep 21, 2015 05:20 PM
reallynotamechanic
Sep 20, 2015 05:40 PM
