Pre 84 Trucks 1st gen pickups
Help remove my shifter!!
Old Jun 12, 2014 | 08:18 AM
sandman666's Avatar
I need to pull my trans to find out what is going on in the bell housing and I am also replacing the shift socket and bushing. But I can't get the shifter out. Advice??
Old Jun 12, 2014 | 08:48 AM
gillesdetrail's Avatar
Push on the socket at the bottom of the shifter and turn it, it will pop out.
Old Jun 12, 2014 | 08:55 AM
sandman666's Avatar
Are you talking about below the spring? Or are you saying push shifter down and turn? Which direction do I turn or does it matter
Old Jun 12, 2014 | 09:02 AM
MaK92-4RnR's Avatar
There's an aluminum cap on it. Push down, and turn. itll pop. IF you pull on it, you'll break it, and you will not be able to lock the shifter anymore. causing it to pop out when you drive
Old Jun 12, 2014 | 09:03 AM
sandman666's Avatar
Gotcha now clockwise or counterclockwise ?
Old Jun 12, 2014 | 09:58 AM
kawazx636's Avatar
^^ X2
See the part in your picture that is missing on my tranny shifter in my picture below? That's the retainer that you have to push down and turn off - It's not even 1/8 of a turn and I believe it turns off to the left.
Old Jun 12, 2014 | 11:35 AM
enigmaT120's Avatar
I think I would clean most of the dirt off first, as some will probably fall into your gear box the way it is.
Old Jun 12, 2014 | 11:51 AM
Nervo19's Avatar
Thinking the same thing. That would not be good. That looks like GA, NC or VA red mud.
Old Jun 12, 2014 | 12:40 PM
sandman666's Avatar
Texas Mud!!! Got it off and my shift ball seat is totally gone!! I assume it goes under the spring, is that correct?
Old Jun 12, 2014 | 12:55 PM
sandman666's Avatar
nevermind, found what I needed on the marlin crawler page. thanks for everyones help with the shifter though!!
Phantez
Aug 28, 2015 10:02 AM
skypilot
Aug 25, 2015 01:09 PM
Motomonty
Aug 9, 2015 05:53 PM
Tonetrk
Aug 3, 2015 08:47 PM
crashburnoveride
Jul 10, 2015 06:39 AM
