Pre 84 Trucks 1st gen pickups
1983 4x4 inside of cab getting to warm
Old Sep 25, 2014 | 03:56 PM
joesgarage's Avatar
Floor boards get to warm, which makes the inside of cab feel to warm. Should i insulate the floor boards?
Old Sep 25, 2014 | 04:03 PM
83's Avatar
83
Did you loose the exhaust heat shields?
Old Sep 25, 2014 | 04:04 PM
Old_ blue's Avatar
ru missing the heat sheild piece of metal above the exaust under the cab? its above the cat.
Old Sep 25, 2014 | 04:16 PM
joesgarage's Avatar
Thanks for the fast reply!! im not sure, but ill look when i get off of work. if missing, is that a piece i find easy?
Old Sep 25, 2014 | 04:30 PM
joesgarage's Avatar
im thinking about getting a stickey heat shield for the bottom of the cab. would this help the heat from entering the cab?
Old Sep 26, 2014 | 10:09 AM
Schnayke's Avatar
is your gear shift boot bolted down? my old 2wd had like one bolt in and tons of heat would come in there. once i bolted it all the way down it was fine again.
Old Sep 26, 2014 | 09:01 PM
joesgarage's Avatar
I'll check that too, thanks. But I really should some heat shield material under the cab.
Old Sep 30, 2014 | 10:18 PM
CAdot's Avatar
Old Oct 8, 2014 | 06:13 AM
joesgarage's Avatar
heat sheets
has any one used those self sticking heat sheets on the floor boards of the truck? do they keep the heat from coming in from the engine/tranny/? Thanks guys for the input!
Old Oct 8, 2014 | 09:22 AM
dropzone's Avatar
Fossilized
I used "peel & stick (or seal)" , from lowes, kind of a poor man's dynomatt. Works but you still should have the heat shield underneath above your cat.
Trans and transfer case fluids low will also generate excessive heat
Attached Thumbnails 1983 4x4 inside of cab getting to warm-20141008_101946.jpg
Old Oct 8, 2014 | 09:47 AM
joesgarage's Avatar
heat sheet
So you lined the inside of the cab?
Old Oct 8, 2014 | 10:03 AM
CAdot's Avatar
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Jonny246
Jul 12, 2015 04:51 AM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
Steezy96yota
Jul 6, 2015 10:00 AM
