Pre 84 Trucks 1st gen pickups
22R Water Pump Question
Old Apr 2, 2014 | 06:12 PM
mtrdud's Avatar
My computer that had my FSM on it crashed so I can't access it. When installing a new water pump on a 22r is there any FIPG required or is it just the gasket?
Thanks
BTW it's a 83
Old Apr 2, 2014 | 06:28 PM
slacker's Avatar
gasket is all that is in The FSM .. but I always use a "skiff" of FIPG , if for nothing else then just to hold the gasket in place .
Old Apr 3, 2014 | 03:20 AM
mtrdud's Avatar
Water Pump
Thank you sir
Old Apr 7, 2014 | 10:23 AM
mtrdud's Avatar
Anybody know the torque amour for the water pump bolts? There's not any listed in the FSM.
Old Apr 8, 2014 | 06:38 AM
kawazx636's Avatar
Per the 1985 FSM that I have (under the Standard Bolt Tightening Torque section), FLANGE hex bolt torque specs are as follows:
6x1.00 - 52 in-lbs
8x1.25 - 10 ft-lbs
10x1.25 - 21 ft-lbs
12x1.25 - 39 ft-lbs
14x1.50 - 61 ft-lbs
You can use this as a guide since the engines are practically the same; however in the Service Specifications Section of my 1983 FSM (or anywhere else for that matter) there is no torque specified for the water pump. In that same section it lists the torque specs for the oil pump at 14-18 ft-lbs. In my 1985 FSM on page EM-44, it lists the specs for all timing cover bolts (cover, water pump and oil pump) as 9ft-lbs for 8mm bolts and 29ft-lbs for 10 mm bolts. When I rebuilt my 22R I used the torque specs from the 1985 FSM. I would stick to something around 10 ft-lbs
Old Apr 13, 2014 | 07:50 AM
Erick561's Avatar
From: I ship from New London Connecticut I PriceMatch
if your timing chain cover has studs threaded in to the water pump threads, then you can torque the nuts to 14 ft lbs
Old Apr 13, 2014 | 10:39 AM
mtrdud's Avatar
Water Pump
I installed it a couple of days ago and went with 10.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
TammyMarie
Jul 15, 2015 11:14 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
