Pre 84 Trucks 1st gen pickups
At my wits end with this truck
Old Aug 10, 2014 | 05:08 AM
yodacrawler89's Avatar
Ok guys I'm loosing here . I'm working on a 81 truck that I have swaped an 87 4 runner 22re in . I swaped the entire harness the only thing I had to hard wire was the ignition switch And the clutch cancel switch . I have checked all the timing and everything is timed right . The truck keeps throwing a code 11 . 11 consecutive flashes no pause. So when you turn the key it fires like it's going to start but does not fire up . Now if you hold the gas pedal to the floor and crank it it will fire up but misses very badly and will only run as long as your pressing the pedal. I have swaped out the ecu and the afm with several good working ones and it does the same thing . So last night I held the afm door open and had my brother crank it . Stumbles at first but then smoothes out good after a couple seconds as long as you hold the door open on the afm soon as you let go it will stumble and shut down. Any ideas on this guy's ?
Old Aug 10, 2014 | 09:50 AM
toastyjosh's Avatar
read some off this,
http://www.pirate4x4.com/forum/toyot...-swap-faq.html
http://www.pirate4x4.com/forum/toyot...-22r-22re.html
http://board.marlincrawler.com/index.php?topic=84366.0
You will need to peovides us with more info as well, what did you do about the gas tank?
Which fuel pump are you using?
That type of stuff
matrad
Aug 26, 2024 08:21 AM
bigblue82
10
Jul 6, 2015 08:27 AM
saphirekosmos
Jun 22, 2015 10:26 AM
RgrChu
Jul 13, 2002 08:53 AM
