Pre 84 Trucks 1st gen pickups
Door Window Glass Install
Old Jul 3, 2014 | 09:20 AM
mtrdud's Avatar
I have a 83 4x4 with the vent window. A couple of weeks ago I slammed the drivers side door a tad hard and shattered the window. I just got a used replacement window. I haven't tried to get I in there yet but before I have at it, what's the suggested way to get it in? Do the tracks need to come out ?
Old Jul 3, 2014 | 10:30 AM
nothingbetter's Avatar
having never seen one but having taken hundreds of other doors apart, I'd say the main window will have to be removed and the track inbetween the 2 windows. Then there will likely be a screw under the door seal at the top of the vent window. You may have to take out the window regulator depending upon design. If its a manual window you'll have to remove the horseshoe clip on the back side of the window crank in order to get that off.
Old Jul 6, 2014 | 03:29 PM
mtrdud's Avatar
Window install
Got it done. I had to take the vent window part out to get the big glass in place. It wasn't bad at all.
Old Jul 7, 2014 | 04:32 AM
RobotMoose's Avatar
Good work!
It's pretty straight forward, all things considered, the pain is getting the wing window assembly out.
I'm in the process of cleaning, weatherproofing, and soundproofing my doors, and might post up my teardown and reassembly pictures for reference. If you'd like to share what you'd learned, I'll PM you when the thread goes up!
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
RustBucket
Jul 24, 2015 04:46 AM
icentropy
Jul 14, 2015 10:23 AM
