Pre 84 Trucks 1st gen pickups
can you identify this?
Old Nov 2, 2014 | 01:28 PM
Juhjuhjinx's Avatar
Anyone know what this is and where I can get a new one? I busted off one of the lines doing something
Old Nov 2, 2014 | 02:41 PM
2000PRE's Avatar
I think it's the high altitude compensater. Not all trucks have them.
Old Nov 2, 2014 | 03:25 PM
dropzone's Avatar
Fossilized
Bingo
Old Nov 2, 2014 | 03:30 PM
Juhjuhjinx's Avatar
Where can I buy a new one?
Or can I leave #7 hose unplugged?
Old Nov 26, 2014 | 08:08 AM
KCsNATION's Avatar
where do the hoses go to the carb or some where else, if the go to the top of the carb right next to the air inlets then you can block those off, most trucks have them blocked off but if not then let me know. really need more pics.
Old Nov 26, 2014 | 09:38 AM
g3bill2's Avatar
Might be wrong answer?
Hard to tell whats broken, guess its the hose nipple. If you have some skils and some idle time you can clean the area real well and lightly sand both sides of break wouldn't hurt. Wipe with a q-tip and perhaps acetone, then use epoxy-gel (regular epoxy is too brittle imo) to bond the nipple (dont get excitited . once hard apply a layer of gel over lapping the bonded connection at least 1/4" to reinforce. I've done this repair many times and lasts well but as you now know we can't pull hard on these old plastic parts like they were new. Wait at least 24 hours before attaching hose, 48hrs is better.
ps. I've done this also if you want a good looking strong fix, splice the broken piece with a small brass tube into ID of plastic using a very light coat of gel-epoxy.
Old Jan 15, 2015 | 03:54 AM
x4xRunner's Avatar
Are these only on carbureted 22r's? Or efi as well? Heading to Colorado this summer and high altitude is a concern,
Old Jan 15, 2015 | 05:39 PM
old87yota's Avatar
I believe that the High Altitude Compensation Kit is only for the carbureted 22rs. The computer on the 22re should compensate for the thinner air in higher altitudes.
Corvoid
Oct 13, 2015 08:55 AM
JUICE222
Oct 13, 2015 08:50 AM
Bill854x4
Sep 20, 2015 04:32 PM
jdt79
Sep 16, 2015 02:14 PM
DadsTruck
Aug 1, 2015 09:14 PM
