Pre 84 Trucks 1st gen pickups
1981 Toyota Hilux Leaf Springs
Old Jul 15, 2014 | 02:24 AM
nomadzoul's Avatar
Hi, so im doing a full restoration to my 1981 Toyota Hilux (single cab) and i was wondering what are the factory settings for the leaf springs. Basically i need to take them to a shop so he can re arch them again ( not sure what the proper word is) but i do not know what the factory settings were. When i asked the guy from the shop he told me how much inches i want.But i do not know for sure all i know is i want them to be the same as stock. my front leafs are basically straight ( no arch at all) and the rear are decent i guess but i want to the dimensions so that i can have them re-set.
Old Jul 15, 2014 | 05:51 AM
RobotMoose's Avatar
As far as I've always seen, the stock front springs were always flat like that.
Or inverted, like mine.
Old Jul 15, 2014 | 12:16 PM
gillesdetrail's Avatar
yes mine were too, sorry not to be much help but from friends experience re-arching springs only lasts for a while then they go back.
Old Jul 15, 2014 | 12:34 PM
toastyjosh's Avatar
http://www.lowrangeoffroad.com/yotam...s-lr-7985.html
Old Jul 15, 2014 | 01:36 PM
RobotMoose's Avatar
I've heard that too.
It's probably in your best interest to just replace them altogether.
Old Jul 15, 2014 | 01:38 PM
RobotMoose's Avatar
The OP is in Malta, I'm not sure Allpro ships there. It would be worth every penny, though. Good suggestion.
Old Jul 16, 2014 | 01:11 AM
nomadzoul's Avatar
Yes indeed that website has some nice goodies , if only shipping didnt cost me 800+ dollars for a set of leafs. if it was more a reasonable price i would buy some nice stuff for my truck
Old Jul 16, 2014 | 01:23 AM
RobotMoose's Avatar
Youch!
I would go custom.
If you have a local shop that makes springs, just take your truck by, tell them what you have, what you want to do with the truck and the kind of weight you typically carry and have them make you some from scratch.
It's a lot better than a re-arch and it'll be much cheaper than overseas freight cost for some USDM off the shelf springs.
Old Jul 16, 2014 | 04:52 AM
And post some pics of your truck!!
Old Jul 16, 2014 | 04:10 PM
nomadzoul's Avatar
I will probably do that , as for the pictures i already posted some in the 1st generation post but i cannot take a lot at the moment since the truck is in bits and peaces due the full rebuild.
Here are some for you just in case you missed them.
Side Views
https://scontent-a-fra.xx.fbcdn.net/...25984134_n.jpg
Side Views
https://fbcdn-sphotos-g-a.akamaihd.n...28373940_n.jpg
Front View
https://fbcdn-sphotos-f-a.akamaihd.n...37804035_n.jpg
Diff Guard
https://fbcdn-sphotos-h-a.akamaihd.n...18583737_n.jpg
Goodies
https://fbcdn-sphotos-d-a.akamaihd.n...f71adadf1f6ee3
Allied Rock A Tons
https://fbcdn-sphotos-f-a.akamaihd.n...34797511_n.jpg
Old Jul 16, 2014 | 04:12 PM
nomadzoul's Avatar
Also i have a power steering complete kit off a 1991 Toyota Hilux which fits directly (Same chassis bolts and same engine bolts) which i will be fitting aswell so this will also be power steering.
and this is my goal + a set of tube bumpers
https://scontent-a-fra.xx.fbcdn.net/...95376905_n.jpg
Old Jul 17, 2014 | 04:55 AM
kawazx636's Avatar
I think that you would be wasting your time and money by re-arching your springs. It won't take long to get back to the same old sag, if not worse - I've seen it attempted several times before and each one failed. If you are dead set on stock springs and stock ride height, Low Range Off Road has the front springs (at a good price too) but you'll have to do some searching for the rear springs. If you're ok with a little bit of lift on an aftermarket spring, I would highly recommend Old Man Emu. They have a 2" lift and are hands down the best riding stock length aftermarket spring available.
Old Jul 17, 2014 | 05:18 AM
nomadzoul's Avatar
i already have a 5" lift kit from Marlin Crawler , so lift doesn't bother me at all , i don't want it to be a monster truck so i'm not looking for a huge lift , i want to keep leafs as stock as possible so that with the lift kit and 33" tires the truck will have a good stance. Only problem is from Low Range Off road the shipping is just too expensive. i will try to see if i can find something more local . maybe find a dealer in the Europe.
Jun 1, 2021 01:51 PM
nick b
Jul 11, 2015 04:38 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
