Pre 84 Trucks 1st gen pickups
Coolant in oil?! What to do, what to do.
Old Apr 15, 2026 | 12:16 PM
tpd143's Avatar
Hello all, made a rather unfortunate discovery regarding my long time project ‘82 SR5 4wd. In the eleven plus years I’ve owned it, it’s never been put on the road. Been working on it here and there, main thing it needed was body and paint and that’s all done. Long story short, decided to wait on the little things and start enjoying it. Went to change the oil, and discovered an oil pan full of coolant. Not peanut butter milkshake, coolant, then oil. Pulled valve cover and found the milkshake there. In the short time it’s ran since I’ve owned it, there’s been no sign of a blown head gasket. Trusted mechanic who rebuilt the carb, checked compression and smogged the truck way back when I first got it gave me no indication there was a problem. Anyway, I’ve gone from a couple hours worth of work to get it on the road to ?? What course of action would you all recommend? TIA.
Old Apr 15, 2026 | 07:39 PM
the_supernerd's Avatar
Since it has been sitting for 11 years, I would pull the oil pan to make sure it is not a rusty mess in there in case the coolant started leaking years ago. The next thing would be find out where the coolant came from. I would assume head gasket, but as you probably know, the 22r engines with plastic guides can break and the chain eats through the cover into the water jacket. '82 should still have steel guides, but it is worth checking in case it is not the original engine or someone put a cheap plastic guide in before you got it. There is also a chance that the timing cover cracked or the gasket sprung a leak internally. With the valve cover and oil pan off, try pressurizing the cooling system with a tester to see if you can see coolant flowing out anywhere internally. It could also be possible for a crack or gasket problem in the intake manifold to leak coolant into one of the cylinders that would slowly trickle around the rings into the oil pan. Coolant can turn acidic after a few years, so it may have been fine 11 years ago but dissolved something over time.
It seems like every time I get a vehicle back on the road that sat for an extended period of time there are always new problems that arise within the first 100 miles or so. It can be frustrating, but getting the engine in good shape now will be worth it when you take it out for the first time.
Old Apr 18, 2026 | 06:41 AM
13Swords's Avatar
5 Year Member
the_supernerd knows what he's talking about and I totally agree. Since you've already got the valve cover off get a strong flashlight or light source and have a good look down on the timing chain, and especially look on the driver's side. That's the guide that will usually break and allow the chain to eat into the timing cover and into a water jacket, allowing the oil & coolant to mix. If you've never changed the timing chain set out before now this would be a great time to do it, especially if you pull the oil pan too. If you've never had that pan off before it' deserves a cleanout at the least, plus a new gasket.
Since your mechanic compression tested previously and found no issue with the numbers, I'd doubt it's the head gasket.
Old May 4, 2026 | 05:53 AM
tpd143's Avatar
Awesome, thanks for the info guys.👍
Pena
Jun 28, 2022 08:32 PM
runnaround
Sep 19, 2013 08:44 AM
rywoody
Jun 13, 2009 11:31 AM
firebane
7
Dec 12, 2008 09:14 AM
Scroff
Nov 12, 2008 01:49 PM
