Pre 84 Trucks 1st gen pickups
GM 3 wire Alternator wiring
Old Aug 25, 2023 | 10:01 AM
Sirgearhead7@gmail.c's Avatar
Hello, I'm looking to install the GM 3 wire onto my 82 pickup
https://lowrangeoffroad.com/gm-3-wir...acket-kit.html
I have a 5 wire Voltage regulator.
3 wire to factory alternator
Yellow, Green , White with black stripe. ( green round connecter)
And then a single white wire coming from the alternator.
Any good info on wiring?
Thank you
Old Aug 25, 2023 | 02:50 PM
81 4X4's Avatar
This should do it. One large red wire from a battery hot, (you can use the battery hot that goes to your original alternator). #2 on the new alternator jumps to the battery hot, and the white wire, #1 isn't needed.You don't need to cut your original wiring harness.
Old Sep 10, 2023 | 02:48 PM
Thanks for the help. I belive the charge light is the yellow wire on a 82 pickup.
I used 6 gauge with a circuit breaker for my power wire.
Jakez
Aug 22, 2018 09:52 PM
KSA
May 30, 2017 07:13 PM
oleblue22
Nov 16, 2016 07:12 AM
BURR2OF4
May 22, 2011 06:46 PM
dieselcruiserhead
Feb 8, 2010 08:54 AM
