Pre 84 Trucks 1st gen pickups
Differential Pinon Nut
Old Jun 25, 2008 | 04:57 AM
trk4sale's Avatar
Is there a trick to un-staking the pinon nut? I thought it would be easier to change the pinon seals with the engine out, but I'm having a hard time removing the nut. I'm thinking it might be easier to grind the nut with a dremel tool and use a new one after I change the seal.
Old Jun 25, 2008 | 05:42 AM
zlathim's Avatar
I sometimes have luck using a center punch and hammer to uncrimp.
Your idea will work, but don't grind anything except the staked portion of the nut. Grinder vs. pinion shaft = not good. Replace the nut with a new one.
Old Jun 25, 2008 | 06:36 AM
4Crawler's Avatar
Here is how I do mine:
http://www.4crawler.com/4x4/CheapTri...eal/index.html
Old Jun 26, 2008 | 06:09 AM
trk4sale's Avatar
Thanks for the info. I'll try a different punch with more taper to the point and see if that will work. I didn't have any problems on the transfer case nuts, but the diffs are way tougher.
justdifferentials
14
Jun 11, 2017 08:36 PM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
