Pre 84 Trucks 1st gen pickups
82 Truck No Start
Old Mar 11, 2008 | 08:10 PM
myyota's Avatar
82 Truck No Start
My cousin has an 82 toyota truck that won`t start, it will turn over but there is no spark. He tryed a different coil but nothing changed. he told me that there is no power to the coil, so im thinking its one of two things, either the ignitor or possibly the ignition switch, any help or opinions are appreciated.
Old Mar 11, 2008 | 08:20 PM
rowdy235's Avatar
try different ignitor/coil that you know works, if that doesen't work I'd bet on ignition switch.
Old Mar 11, 2008 | 08:55 PM
DeathCougar's Avatar
Ignitors are well known for failing in those early trucks.
And keep in mind there is a difference between the Coil and the Ignitor. The coils in these trucks NEVER fail. The Ignitors do.
Old Mar 12, 2008 | 07:50 AM
scottd's Avatar
If you don't already have one, get ahold of an FSM. It tells you how to test the ignitor (it's not too hard to do). As suggested above, you could try another ignitor and coil. I would only do that if you can find a good used one cheap. A new ignitor is very expensive (about $300) so make sure that is the problem before buying a new one.
Old Mar 12, 2008 | 08:00 PM
myyota's Avatar
I will try and find a used ignitor, what year range can i look from, is it 81-83 ?, i don`t know these early trucks that well.
Old Mar 12, 2008 | 08:14 PM
Sked's Avatar
Anything from 79-83 will work. Not sure what was used on the 84+ carbed engines.
bigblue82
10
Jul 6, 2015 08:27 AM
Badger62811
Jun 26, 2015 09:26 PM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
