Driveline removal
Driveline removal
Hey, I know this is pretty simple, I've done it before but it was a long time ago and I don't recall having a problem but..I got the 4 bolts off the front end of the rear driveshaft, but can't get it to separate from the transmission. I don't know how much I can abuse it to get it off, plus my engine's out, so when I really shake the driveshaft, the tranny's moving around quite a bit too...don't want it fall over!
Anyway, can I just hammer on it, or is there a little trick to getting it to separate?
I find there is usually a notch on one side of the flange that you can get a chisel or large screwdriver into and either pry it loose or drive it in between the two flanges to separate them. Less likely to damage something as you are hitting the chisel. And a rope or bungee cord to catch the shaft when it falls free is a good idea.
Won't effect balance at all. Driveshafts are balanced outside the vehicle to begin with. I've had mine out many times with no ill effect on balance.
Thanks, great advice. I was a little scared to pry between the two..I've been doing so much engine work lately with surfaces you don't want to scratch, so I was hesitant, but if it's cool I'll try that first.
Good idea with hitting it with bolts still on a bit, too. Kinda like leaving those last few threads on the steering wheel nut on before pulling it loose so you don't smack yourself in the face with the wheel when it comes loose
Unless I need the room, I'll just be leaving the differential ends connected, I'm just taking the transmission out, but I did mark it anyways since the manual says to. I think I need the front shaft rebuilt, actually though, so that one I'll need to mark. Thanks a lot everyone.
You say that now, but I removed the DS on my truck and put it in backwards and odd I had this vibration. I flip it around and it goes away???
http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
I've never run into this on my truck, though.
Yes, sometimes the shaft will balance/phase better oriented one way vs. the other, all depends on how well centered the flange is:
choppe777
May 16, 2016 08:00 AM
