Pre 84 Trucks 1st gen pickups
humming/ vibration coming form the rear end
Old Jun 13, 2008 | 11:07 AM
manuk's Avatar
ok guys, "beast" is in trouble! i need to get this fixed ASAP b/c its my DD. so a few days ago i started hearing this humming/ vibration coming form my rear end from 60-65 mph, and it just seems to be getting worse and yesterday i started hearing some clicks and clacks coming from the rear right off of the take off, but not after ive got the truck moving. so, finally i stopped driving it because i dont want to leave my driveshaft on the freeway. so my question is, any idea if this is from one of the u-joints, the driveshaft, the output shaft bearings in my tranny (5speed manual), or worse case senerio, something in the rear pumpkin?
-thanks
Old Jun 13, 2008 | 12:02 PM
4Crawler's Avatar
Block the tires, tranny in neutral and climb underneath the truck and grab ahold of the driveshaft and feel for any play at all the moving parts.
Old Jun 13, 2008 | 12:25 PM
manuk's Avatar
ok, correction. the clicking sound seems to be coming from the front of the rear driveshaft. secondly, i did check for play in the driveshaft. it feels like its not coming form the u joints. i grabbed the front u joint with one hand and twisted the shaft back and forth with the other hand to feel for play, and same with the rear. there is some play in the rear but it feels like its in the diff. not in the u joint. ive heard that it could be the u joints even if theres no play in them..
Old Jun 13, 2008 | 01:44 PM
Al's Chop Shop's Avatar
U-joints!!!!
change them quick before you lose your shaft on the road.
Al
Old Jun 13, 2008 | 01:47 PM
zlathim's Avatar
That is true. Remove the DS and check the joints. Pull the caps and check to see that they are lubed properly, etc. I have seen them dry of lube and causing vibration, but still feel tight on the rig.
Old Jun 13, 2008 | 02:07 PM
vtjeenyus's Avatar
check your wheel bearings
mine did the same thing ...found two of the balls inside the bearing welded together
lots of noises
Old Jun 13, 2008 | 04:22 PM
manuk's Avatar
Al, this is kind of a stupid question but im guessing its a better idea to replace both of them while im at it right?
Old Jun 13, 2008 | 09:50 PM
Sked's Avatar
x2 on checking wheel bearings, i swapped out mine 2 weeks ago and it is so much smoother.
Old Jun 14, 2008 | 11:43 AM
might as well, beats crawlin under there a second time 3 months down the road. if one is bad, the other can't be too far behind.
Al
Old Jun 14, 2008 | 03:43 PM
manuk's Avatar
alright guys ill let you know how it goes. thanks for the advice.
Old Jun 14, 2008 | 04:53 PM
crawyota's Avatar
From: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
Originally Posted by Al's Chop Shop
U-joints!!!!
Al
x2 I had the same issue , and i was so close to losing the driveshaft
Old Jul 14, 2008 | 03:58 AM
toyota-erik's Avatar
check to see that the pinion nut hasnt backed off.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
