Pre 84 Trucks 1st gen pickups
Rebuild time
Old May 7, 2008 | 09:39 AM
bruzryoda's Avatar
Rebuild time
damn emergence phone calls!!! started up and took off like a bat out of hell
lastnite from work. got 3/4s way home and herd a knocking sound.. got home made sure everything was cool. went out hoping that i had a badly fouled plug. nope!!! got spark? YUP!!! broke the compresion tester. #1, 145. #2, the same. #3 0. #4, 20psi. called around for a used engine but to no aval. called some machine shops, 4 said bout 1500$ finally got referd to a shop that told me pull it, strip it, bring it in, he will bore it polish everything, new pistons the whole yard for around 450.00 just the block. does anyone know anything bout a comp 260 cam kit for yotas??????? any pros and cons, advise would b appreciated??? i was running a weber and a 2 1/4" exhust from the Ypipe to the back...
Old May 7, 2008 | 10:37 AM
bruzryoda's Avatar
yes it is an 81 sr5 w/a 22r. im curious bout that cam kit?
Old May 7, 2008 | 01:45 PM
Sked's Avatar
I got the new 260 comp cam in my truck with the .440 lift on int and ex. You need new valve springs for these things. So far i Really like the cam and it makes decent power off the line to 2500rpm, more than stock as far as i can tell. But then at about 3000-5000 it really starts to make a difference.
If you have the money port match your intake Man to head, Then do a good port job on all the intake and exhaust runners and a good valve job. A weber, good head&cam, and header&exhaust should make a decent upgrade, just dont cheap out on parts like cheap timing chains and bearings.
bigjstang
Jun 2, 2025 03:56 PM
jerusry
Oct 19, 2015 05:28 PM
Yota.Jay
Jul 23, 2015 08:08 PM
karbin
Jul 5, 2015 11:37 PM
Vargntucson
Jul 4, 2015 12:15 PM
