Pre 84 Trucks 1st gen pickups
alternator tested good..now what
Old May 24, 2008 | 05:04 PM
camo31_10.50's Avatar
ok..so we tested the alternator at oreiley's...and it tested good...and autozone..also same result...so we think the Alt. is good...then we moved on to the voltage regulator...which is bad now...(popped one of the contacts off)..but it was ok before that...and the battery is fine...what else could it be...thanks for the help!
Old May 24, 2008 | 05:08 PM
Nughuffer's Avatar
Bad Ground
Check your grounds. I just went through similar
Old May 24, 2008 | 08:45 PM
dropzone's Avatar
Fossilized
battery cables, grounds, fuses etc...
Old May 24, 2008 | 09:47 PM
nv4runner's Avatar
Make sure you check the wires that plug into the generator for breaks or bad connections as this may also give you a no charge situation.
Old May 24, 2008 | 10:15 PM
georgiayota's Avatar
Id say check your connections and check for broken wires/cables... on old trucks like ours they tend to get trash it them and corrode or break
_Nicco_
Sep 21, 2015 03:06 PM
LotOMiles
Sep 14, 2015 11:45 PM
sanctfy
Sep 13, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
some drunk guy
Sep 4, 2015 11:55 PM
