Pre 84 Trucks 1st gen pickups
wiper arms...
Old May 23, 2008 | 01:39 PM
Al's Chop Shop's Avatar
wiper arms...
the blade mount that has the two screws that attaches it to the arm is fubar on mine so i can't change out the blades, so i figured i'd get new ones from the stealership. they must be gold plated because they want $62...... A PIECE!!!
so i figure i'd try ebay, but i find no listing for wiper arms before 84, only 84-88. are they the same, or at least interchangeable? i can't imagine there would be much difference, but maybe they changed the linkages and the arms are a different length or something. anyone know for sure?
Al
Old May 23, 2008 | 05:35 PM
refried's Avatar
The splined shafts are different, the early style uses a small shaft with a nut holding the arm on. the new style uses a much larger splined shaft without the nut. nobody make the arms aftermarket (Anco,Trico) so your stuck going to the dealer. I have a set of adapters that will make the new arms work with the smaller shafts (you do have to drill the arm for the stud) but I haven't tried them yet.
Old May 23, 2008 | 09:34 PM
dropzone's Avatar
Fossilized
Al: Check some of the U Pull it's around town. there have been a ton of 1st Gen 2WD and 4WD trucks showing up lately. I was at the Tigard (more like sherwood) off 99W on Monday and there were 4-5 trucks there. Might get lucky...$62 WOW!?!?!?!
Old May 24, 2008 | 11:06 AM
thanks robb, i think i have a line on one locally but if that doesn't work i'll stop by the u-pull-it. my shop is in sherwood so its not far from me.
Al
Old May 24, 2008 | 07:01 PM
Island_Yota's Avatar
I threw some of those out when I did a big cleanup after my build, Probably a bad idea? I got the ones that are on my truck off a parts truck at a junkyard for free, I took them because they had nice wiper blades on them.
Old May 26, 2008 | 08:36 PM
myyota's Avatar
Al
Go to www.partstrain.com and you can get complete new wiper blades from 8.00 to 21.00 dollars depending on which ones you buy and they come with new screws also. Ive bought two sets and they seem to be good quality.
okamikai
Apr 30, 2018 10:19 PM
ghostmoney
Jan 28, 2018 11:42 AM
pickle6415
Dec 25, 2015 07:34 PM
PNW94Runner
Sep 29, 2015 02:55 PM
VT2LAB
Sep 10, 2015 09:36 AM
