Pre 84 Trucks 1st gen pickups
32/36 dieseling when shut off
Old Jun 16, 2008 | 07:53 PM
kj1074's Avatar
Specs: rebuilt motor, new 32/36, wide open exhaust.
do yall think the wide open exhaust could cause a dieseling when i shut her off? i tried to lean it out, checked all vacuum and no leaks. Im stuck!
thanks guys.
Old Jun 16, 2008 | 08:01 PM
82greenbeast's Avatar
hmmm, timing maybe? But what do you mean by dieseling?
Old Jun 16, 2008 | 08:06 PM
georgiayota's Avatar
it could be the lack of back pressure because of the open exhaust
Old Jun 16, 2008 | 08:35 PM
kj1074's Avatar
timing is set at 8 to factory specs; by dieseling i mean when i shut it of it does an extra revolution on its own. im thinkin lack of back pressure is the cause, it didnt do this till i hit a deer and it ripped all the exhaust off, ive had trucks in the past run wide open like this with no problem, just never a 4 popper. think its that sensitive?
Old Jun 17, 2008 | 12:25 AM
Sked's Avatar
Is your linkage not fully going back all the way or is the choke semi on still? If my rmps are over say 950ish when i shut it off it will diesel for a sec or 2
Old Jun 17, 2008 | 12:34 AM
91Toyota's Avatar
Hmm...it possibly could be because of no back pressure.
BTW...Nice bike! I've got an '01 sv650s...they are excellent bikes.
Are you a member of svrider.com? <- Great site!...I'm a member over there.
Old Jun 17, 2008 | 04:00 AM
Ganoid's Avatar
Try and sweeten up (richen) the idle mixture. Leaning it out will only cause it to diesel more often as a lean condition is more prone to pre-ignition hence ignition before it has a spark to ignite it.
Old Jun 17, 2008 | 08:11 AM
kj1074's Avatar
smart Ganoid i didnt think about it like that. before i figure anything out with it though i have to get my exhaust put back together. its still covered in deer parts.
91Toyota- yes i am a member of svrider.com! i just got my bike back after a 6 month hiatus so i been posting again, same name there too.
Old Jun 17, 2008 | 11:44 AM
91Toyota's Avatar
Sweet man! I'm 2001SV650S over there...I'm sure you've seen me around
See you around!
Pri$erulz
Nov 17, 2019 08:03 PM
presto30
Engine Swaps
Dec 10, 2015 12:01 PM
kawazx636
Sep 29, 2015 08:22 AM
voiddweller
Sep 28, 2015 11:21 PM
runnermedic
13
Sep 21, 2015 05:20 PM
