Pre 84 Trucks 1st gen pickups
Front Drive Shaft
Old Jul 28, 2008 | 09:04 AM
camo31_10.50's Avatar
Front Drive Shaft
what is the Stud diameter on my '80 front driveshaft...im going to replace the CV joint or whatever thats on the end of the shaft (where it connects to the T-case) up there by the double u-joint part...theres a stud in there...and im needing to know the size of it..its either .47 or .511...and i cant measure the size of it at the moment...thanks for the help..if any of you guys even have a clue about what im talking about...idk how to explain it any better..lol sorry
Old Jul 28, 2008 | 10:58 AM
dropzone's Avatar
Fossilized
To be honest, I don't have a clue as to what you are talking about...
The front CV joint is called a Double Cardan:
Only thing my Factory service manual says:
Inspect front propellor Shaft
a) inspect shaft for wear or damage
b) inspect the double Cardan joint for wear or damage
NOTE: if any problem is found, replace the front propeller shaft (page 12-5)
--which sucks because they have 8 pages on driveshafts but no exploded diagrams of the front shaft, only 1 picture and what they said above..
I looked over my latest craigslist find ($35 , looks to be recently rebuild and tighter than crap compared to my old one)--soon to be converted to long travel for the dual
The only thing that resembles a shaft to me would be the U joint bearing caps..
maybe the local driveshaft shop can help....
I really want to order new shafts from either these guys:
http://www.4xshaft.com/index.html
http://www.reeldriveline.com/
sorry--probably did not need that stuff but maybe they can figure out what you need
Old Jul 28, 2008 | 07:20 PM
ok..so in your second picture..there is a u joint at both side of the pic (the double cardan) in the middle...there is some kind of ball joint thingy...im needing to replace that...i know it can be done..because NWOR has the part i need to do it with...LOL
Old Jul 29, 2008 | 05:07 PM
brooklee1000's Avatar
Tricky to get apart. You have to watch that the needle bearings don't fall out of the center during disassembly and reassembly. Use grease to hold them in place for reassembly.
Old Aug 16, 2008 | 05:25 AM
dropzone's Avatar
Fossilized
Hey Camo:
Just found this article over on 4x4 wire about clearancing a driveshaft CV.
know it is bit late and maybe you got the shaft fixed but remembered your thread...shows how to get the thing apart:
http://www.4x4wire.com/toyota/tech/cvmod/
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
