Pre 84 Trucks 1st gen pickups
Clutch Question
Old May 18, 2008 | 09:34 AM
camo31_10.50's Avatar
Clutch Question
ok..so got my '80 all back together...started driving it..drove it for about 1 1/2 weeks..then i got hardly no pressure on the clutch peddle...until it gets about 3 or 4 inches from the floor...so i started adjusting my slave cylinder..(i was told by somebody else to do that) and then i got back inside...had goood pressure on the clutch...then all the sudden i had NONE..so i bleed the slave then went back and had good pressure..then it busted the seal inside the slave...so...wtf...i replaced the slave...and NOW it's just like before..no pressure until almost all the way to the floor...but it only work if i take the spring off of the clutch fork...if the spring is on there....it wont work...i thought i might have a leak...but its not leaking...anybody got any advice??
Old May 18, 2008 | 12:00 PM
bump...
Old May 18, 2008 | 07:03 PM
damn...where's all the first gen tech people...
Old May 18, 2008 | 08:26 PM
Dustin Songer's Avatar
did you put an aftermarket clutch in there?
Old May 18, 2008 | 09:00 PM
rowdy235's Avatar
is the pedal adjusted properly?
Old May 18, 2008 | 10:05 PM
Sked's Avatar
What kind of shape is your clutch Master in? Sometimes the seal around the shaft that the pedal pushes leaks and lets air in/fluid out. Besides that just play around with your pedal setup if your sure its bled good.
Old May 19, 2008 | 04:47 AM
im pretty sure the peddle is adjusted properly...theres a mechanic coming by the house sometime to do the headgasket for the '86 yota 4x4....i'll have him take a look at that peddle to check it all out...thanks again guys...
the1998sr5
15
Jul 14, 2020 08:35 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
upongame619
Aug 1, 2015 12:12 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
