Pre 84 Trucks 1st gen pickups
Where is 79 P/U AC Pressure switch?
Old Aug 14, 2019 | 06:46 AM
faber's Avatar
AC was previously working - Compressor center not turning now - fan is fine - When I turn on AC I get a noticeable uptick in engine RPMs...but no cold air - thought I'd check/clean/reconnect the pressure switch but I've no idea where it is..Any insights? Video at
Thanks,
Old Aug 17, 2019 | 02:01 PM
faber's Avatar
Etc...
So cleaned up connection from compressor to main harness(?) and compressor is now spinning when AC is on - still no cold ac yet and I'm not sure my cleaning resulted in spinning compressor- and I've been in and out off dash so much I may have screwed something up - maybe the pressure switch is behind glove? Do you guys want to see a gem of a 79 fully operational or not? (-*
Old Sep 14, 2019 | 07:31 AM
toy_tek's Avatar
If the compressor clutch engages when you turn a/c on, then the switch is doing it’s job. Sounds like you don’t have any refrigerant in the system.
If the 79 a/c system is anything like the 80-83 (my guess: it’s the same), then the switch is inside the evaporator box, you’d have to disconnect the lines, remove the box and open it up to access.
Old Sep 14, 2019 | 01:14 PM
faber's Avatar
Re:
Hi Toy_tek and thanks very much - makes sense - yea it appears to be a leak - I added two cans of R134a and had AC for a week - then zilch. Thanks again,
Old Sep 27, 2019 | 08:25 PM
swampedout's Avatar
5 Year Member
Idk if you solved this problem and im not really an ac guy but if this is the stock ac system, you will have problems if youre not using r12
[Edit] i see your other thread...sorry.
Have you got it working now?
Old Sep 28, 2019 | 03:23 PM
faber's Avatar
Hi swampedout & thanks - diagnosed this week w/ a manifold guage and Ferrari Mechanic (2 of em) friends who had a few choice words for Toyota tho they like the truck - "purged" system, and I'm separating lines to get to & replace pressure switch - I "ASS-U-ME" we'll fill with R143A(?) when complete but my intent is to keep stock system - Any specifics regarding your issues or any recommended R12 sources? Thanks,
Old Sep 29, 2019 | 07:07 AM
swampedout's Avatar
5 Year Member
https://www.hagerty.com/articles-vid...ts-and-the-law
Im just going off what little I know. I dont have a car with working ac. Id listen to the ferrarri mechanics over a internet toyota enthusiast/backyard mechanic.
But with that said what kind of people drive ferrarris? dont get me started
Old Sep 29, 2019 | 09:10 AM
tteuer's Avatar
I believe you have to retrofit the R-12 system with R-134 o-rings and seals or the R-134 will leak right out.
Old Oct 1, 2019 | 01:48 PM
faber's Avatar
Re
LOL...damn F-car guys.
Old Oct 1, 2019 | 01:52 PM
faber's Avatar
Re O-rings
Hi & thanks, believe the R-134a will not require new/different O-rings - removing evaporator to get to pressure switch and removing drier per friends' guidance - waiting on a a 29mm wrench to disconnect large nut on low pressure line at firewall. Will investigate your above -
808-3VZE
Sep 23, 2017 07:45 PM
raceman62race
Dec 16, 2012 03:27 AM
toyotarunner92
Feb 28, 2008 04:15 PM
Rhew Runner
Mar 28, 2007 03:07 PM
yellowvwthing
Sep 29, 2006 06:32 AM
