Pre 84 Trucks 1st gen pickups
79 20R Exhaust to manifold gasket(?) and release fork clip Q:
Old May 26, 2019 | 03:41 PM
faber's Avatar
Hi - 2 Qs:
1) Am I seeking an "exhaust to manifold" gasket? here? (See 2d set of 2 pics) and
2) did I place these release fork pins correctly? see first 2 pics
Thanks in advance
Thanks in advance -
Old May 27, 2019 | 09:12 AM
dropzone's Avatar
Fossilized
wow you must have spent a few days cleaning that bellhousing
I checked an old thread i had and looking at a picture of an L-43 clutch fork I am pretty sure you have the throw out bearing retaining clips in correct
Can't help you on the gasket but from what I remember you should be able to use a 22r gasket too
Old May 27, 2019 | 12:55 PM
faber's Avatar
Re:
not a labor of love...
I spent a week cleaning that damn transmission. (-*. Gunk followed by pressure washing had little effect, scrapers and mineral spirits did the trick. Thanks regarding the pins. They look right and fork moves fine with them. That exhaust to manifold gasket inset appears to be 2.5” OD and 2. ID. Thanks for the 22re tip
Old Jun 4, 2019 | 04:46 AM
13Swords's Avatar
5 Year Member
It should be the same as my '78 w/20R engine, if you have the stock pipes*. It took me a LOT of trial & error to find the ones that fit correctly, as most parts listings are vague on location & fitment. I used the following:
FELPRO 23591 - Ring Gasket - 1 & 31/32" Inside Diameter x 2 & 35/64" Outside Diameter
Make sure you get this one specifically; there is another part number listed (23561) that is NOT correct for manifold to pipe. The ID on that one is 1 & 49/64" & OD 2 & 17/64", & does NOT fit; it's too "sloppy" for a good sea from manifold to pipe. I used the 23591 & it sealed up perfectly. The 23561 is intended to be used at main pipe (down pipe) to intermediate pipe flange.
*As always, measure your round flange on the downpipe to be sure of what you have. Previous owners or shops may have substituted later model pipes on the truck.
WALKER 31383 - Triangular Gasket for flange. This is a metal gasket & I recommend it over a composite gasket.
BTW, torque spec on the manifold flange studs/nuts is 33-36 foot pounds.
Dauntless1971
Jun 10, 2018 12:08 PM
easy-3vze
Nov 9, 2016 02:36 PM
astar4runner
9
Jun 1, 2013 02:11 PM
bomhour
May 6, 2013 11:16 AM
