Pre 84 Trucks 1st gen pickups
Can I plug this off?
Old Apr 17, 2019 | 04:45 PM
ToyOkie78's Avatar
Heater hose question.
My heater hose is connected on the drivers side in the usual stub off the lower radiator hose.
My other hose connects in the intake manifold ( see red square in pic ) I noticed today a small rubber hose coming off the pipe from the timing cover to a 90 degree nipple under my intake ( yellow square in pic ) That small section of rubber hose is sketchy & needs replaced, can I just block it off & plug the nipple under the intake or will I lose coolant flow to my heater core ( after market school bus heater set up not stock toyota, not that it matters )
My heater hose is connected in the intake ( red square ) the line I'm wanting to plug off is the lower tube/line coming off the timing cover ( yellow square ). I understand the bottom line flows coolant to heat the intake for cold weather ( borrowed pic, not my engine )
mjninc
Dec 6, 2016 04:34 AM
jentzschman
Aug 20, 2008 01:38 PM
Guardian_Saint
Dec 14, 2006 11:53 AM
JamesD
Jul 19, 2006 09:10 AM
