Pre 84 Trucks 1st gen pickups
82 r23 piston rings
Old Sep 8, 2019 | 09:09 PM
Mwhite49's Avatar
82 r22 piston rings
How many have pulled there piston for new rings or a rebuild and find that the oil rings are completely gummed up? That alone will cause more blow by and more oil loss. Reason I'm asking is some makes never have issues some do. But I keep reading about the r22 engine with over 500,000 miles still going. Can't say that for most American V 8 or V 6.
That's one reason I only use a High Detergent oil. It helps keep things clean.
Old Sep 9, 2019 | 09:46 AM
old87yota's Avatar
The Toyota engine I think you are referring to is the 22R, not r22.
Old Sep 9, 2019 | 03:13 PM
Mwhite49's Avatar
82 22r
That's the one. Sorry for the mix up. I'm still considering pulling the head , then piston and check the rings. I'm dropping the pan tomorrow so at that time I'll be able to take a look at the bores. Hopefully no scoring shows on the cylinder walls. And kitten I can measure the bore to check if it has ever been bored out.
joedever
Oct 8, 2018 01:04 PM
thefishguy77
Feb 18, 2017 02:09 PM
codykthekilla
Nov 4, 2014 06:47 PM
ibornagain
Oct 6, 2008 12:16 PM
RustBucket
May 31, 2006 01:09 AM
