Pre 84 Trucks 1st gen pickups
looking for some Rust advice for my 83
Old May 23, 2020 | 05:41 PM
northoak's Avatar
5 Year Member
A picture says a thousand words... I'm looking for advice on how to patch this rust above my passenger side door. I have access to a mig welder but I'm pretty sure I'd blow right through that thin metal if I tried. My other thought is cutting it out and patching it with fiberglass. Anyone else deal with this specific problem spot? Thanks y'all
Old May 24, 2020 | 07:26 PM
81 4X4's Avatar
It's not hard to weld sheetmetal. Practice on some scrap sheetmetal the same thickness. Watch youtube videos. I wouldn't fiberglass it.
Old May 25, 2020 | 09:05 AM
northoak's Avatar
5 Year Member
Thanks, If I had a garage I could pull my truck into I'd TIG weld some sheet metal on there. Since I don't my only option would be to fluxcore MIG weld it out in my driveway. I'm comfortable doing that on the bumper I built, and the rust on the bed where the metal is a little thicker but this is just too risky. The hole is about an inch or two away from the insulation on the roof of my cab. I'd be pretty bummed if that melted or caught fire. I'll ask some welder friends what they think but the point of my post is to explore options other than welding. Any ideas?
Old May 25, 2020 | 04:11 PM
toyoda addict's Avatar
It is my opinion that anything other than cutting out the rust and welding in new metal is going to be straight hack work. You can remove the headliner and weld it with a mig. Use thin wire and gas, not flux core. You can also plate the backside of the repair to make burning through less likely. If doing this yourself isnt an option I'd suggest looking into paying someone who can. Rust sucks. Good luck.
Old May 25, 2020 | 04:51 PM
81 4X4's Avatar
Flux core welding isn't the best, I wouldn't use flux core. Pay someone to weld in new metal, then finish it yourself.
Old Jun 2, 2020 | 12:51 PM
mholbro's Avatar
A good welder can make this repair look easy....I agree that this may not be the place to repair yourself if you don't weld a lot.
I would repair with the POR15 floor pan repair kit before I used fiberglass....but it will always looks like a patch job.
Old Aug 21, 2020 | 08:38 PM
12abc's Avatar
Steel wool
Wire brush the rusty spot. Punch out the rust in the middle of the hole. Spray ospho like a mad man into the hole in both directions. Push steel wool into the hole tightly. Slowly pour molten lead over the steel wool letting the lead fill the hole and smooth it out with the equivalent of a metal popsicle stick.
binky_rutledge
Oct 6, 2012 04:29 PM
westjohns yota
Sep 30, 2012 09:22 PM
#1Grunt
Nov 27, 2009 03:54 PM
87toypu
Apr 5, 2007 03:03 PM
854runner
26
Nov 7, 2005 03:12 PM
