Pre 84 Trucks 1st gen pickups
2WD bed Vs. 4WD bed...
Old Sep 4, 2019 | 07:46 AM
sent112's Avatar
5 Year Member
Can a 2WD bed be used on the 4WD trucks? Or is the wheel well larger on the 4WD..
Thanks
Old Sep 4, 2019 | 08:04 AM
arlindsay1992's Avatar
They swap and the wells are the same size. Just the 4x4 beds have a wider flare.
Old Sep 15, 2019 | 11:49 AM
slacker's Avatar
actually , the skirts are longer on a 2WD bed (smaller opening) only by ~ 1" though , but they would have to be cut if your using the flare
Old Sep 15, 2019 | 12:40 PM
OldBlueMidnight's Avatar
5 Year Member
I put a 2wd bed on my 85 4wd xtracab. I like the rail at the top turned outward and the double tailgate latch. I believe these were only available on the 2wd which is why I swapped the 2wd bed onto my rig. As I recall the only hiccup was the filler neck connection was slightly different between the two beds, so I had to use the 2wd filler neck as well.
Old Sep 17, 2019 | 10:20 AM
old87yota's Avatar
What year of Truck are you wanting to swap the beds on?
I know this is posted in the "Pre-1984 Trucks" section, but the differences depend on the generation of Truck or Hilux.
Old Sep 17, 2019 | 10:52 AM
sent112's Avatar
5 Year Member
1982 deluxe....
Old Sep 18, 2019 | 02:33 PM
slacker's Avatar
as I stated above .. it will fit , but with some differences .
Chili327
Jan 7, 2016 11:40 AM
Zach_trun
Nov 2, 2015 12:51 PM
Unsung
Aug 12, 2013 09:11 PM
Rntduckman
Apr 15, 2013 05:19 AM
Dannew
Aug 23, 2008 09:42 AM
