Pre 84 Trucks 1st gen pickups
Aftermarket Gauge locations
Old Nov 21, 2019 | 03:07 AM
keycw's Avatar
5 Year Member
Looking for inspiration for putting in some gauges. Where has everyone mounted theirs? I’ve got a 1980 base model.
Old Nov 21, 2019 | 05:20 AM
buckwheat's Avatar
When I bought my '80 a previous owner had mounted gauges under the glove box, not very handy. I purchased a used yota gauge pod from ebay and moved the aftermarket gauges into it. I think I fabricated brackets to hold the pod in, its been 20 years ago...
Old Nov 21, 2019 | 06:38 AM
keycw's Avatar
5 Year Member
if I come across that gauge pod, I think it was an SR5 option?, ill snatch one up for sure.
Old Nov 21, 2019 | 10:28 AM
83's Avatar
83
I'm definitely partial to the stock location, shown in the photo. It's not easy to glance at them quickly, but you usually don't need to see them often anyway.
Old Nov 21, 2019 | 01:09 PM
OldBlueMidnight's Avatar
5 Year Member
I ended up velcroing a tach to my steering shroud. Not very elegant, but I did use the good velcro. My PLX AFR setup has an app, so the smartphone is my AFR gauge (velcroed to steering wheel). I have PLX air intake temp and water temp sensors I'll add to this system eventually. Depending on what you're wanting to monitor, you could look for a wireless / digital option. If one isn't available now it probably will be soon.
Old Nov 27, 2019 | 10:49 AM
swampedout's Avatar
5 Year Member
Depending on what gauges you want, i like to see my tach while driving. Temp and oil pressure can fit below center console if you just want to glance at them every now and then.
i see people using the phone to show digital gauges to the right of the steering wheel. Seems to make sense and easy to mount.
Speedy
16
Mar 29, 2007 11:31 AM
sandiego
18
Mar 26, 2007 08:23 PM
epage46
10
Feb 7, 2007 09:22 AM
