Pre 84 Trucks 1st gen pickups
Moister coming in the door panel
Old Apr 11, 2020 | 06:11 PM
nottoshabi's Avatar
5 Year Member
Moisture coming in the door panel
I noticed i'm getting moisture coming inside the door and soaking into my door panels. I know modern cars have a piece of plastic glued to the door between under the door panel. Does any one know what kind of glue that is? Could I use some kitchen caulking and some thick plastic?
Old Apr 11, 2020 | 11:51 PM
Co_94_PU's Avatar
Its available at the parts store in strips, you need multiple packages, and at your big box hardware store as butyle.
You can use tape in a pinch but it will dry out eventually.
Old Apr 12, 2020 | 06:58 AM
13Swords's Avatar
5 Year Member
The plastic sheeting glued to the door may only keep the water from getting to the door panels. You need to stop the water from getting into the door in the first place. More likely it's the belt-line weatherstrips and/or the window channel felt.
Old Apr 12, 2020 | 09:26 AM
old87yota's Avatar
Water will always get in the door.
The rubber and felt strips are only to minimize the amount of water that gets in, but were never meant to completely seal the window.
That is why there are vapor barrier between the door sheet metal and the interior door panel, and drain holes formed into the bottom of the door.
Before sealing up the vapor barrier, check to make sure the drain holes are not clogged and water can flow freely through them.
Of course, if your rubber and felt strips are in poor shape, then replacing them would be a good idea!
Old Apr 12, 2020 | 11:32 AM
nottoshabi's Avatar
5 Year Member
Thank you for the reply. Im changing the door rubber. Needed to know about the plastic so I can protect the speaker that is going in the door, also the door panel.
highway
Mar 20, 2015 06:15 PM
Jake28296
May 27, 2014 10:29 AM
Myron
Sep 7, 2010 01:15 PM
Trustyrusty
Mar 9, 2008 07:03 PM
VoTran24
Jul 15, 2004 03:53 PM
