I can't find anything on using a gasket sealant on the water pump gasket. I have silicone which I hate and Permatex Aviation grade sealant, the brown stuff you brush on. I have used this product for years on domestic rebuilds. Even the FSM does not mention a sealant. I'm sure my old one had a sealant. This is a new cover and new pump.
Thanks
Mike
Your right about the difference in gaskets. I just installed the pump on the new front cover. I used Permatex Aviation sealer. The good old brown stuff. There is a big difference in pump quality too.
the top pump is an almost exact copy of the original pump. Notice the machined rotor. The bottom is a not so cheap Gates pump made in China. The top was made in Japan. I picked it up from LCE. The Gates cost almost the same amount.
And I used the gasket out of my original Toyota set.
