Pre 84 Trucks 1st gen pickups
Portable abrasive/sand blasters?
Old Mar 17, 2020 | 05:00 PM
faber's Avatar
Been reviewing these to clean up frame and bed - see pics - (Frame under cab can wait) - Will pressure wash first - thinking Ospho to affected areas...Anyone have experience/recommendations concerning? Thanks!
Old Mar 18, 2020 | 01:05 PM
slacker's Avatar
not so much the blaster ... its the air pressure behind it , and especially , the water/condensation it produces . I have an air dryer on my system (SMC) , 3 sand blaster of different sizes , and they all work perfectly .
Old Mar 18, 2020 | 01:34 PM
faber's Avatar
Re:
thanks very much slacker; what’s the size/hp of your compressor?
Old Mar 18, 2020 | 05:36 PM
swampedout's Avatar
5 Year Member
Keep us updated.
looks like a clean truck! Glad its in good hands.
Old Mar 19, 2020 | 10:56 AM
slacker's Avatar
5HP 80 gallon , + I have 2 more 80G storage tanks around the shop ... air dryer is off the main compressor all the air from there .
I can run ~120lbs pressure continuous
Old Mar 19, 2020 | 12:40 PM
faber's Avatar
Thanks very much slacker - If I'm only planning do do this one truck/frame is your above overkill? Looks like a $1500 investment including blaster, altho i assume you operate many other air tools with it. Is there an in-between option? And I assume my labor intensive option is 1) Pressure wash, 2) Electric Grinder w/ brush wheel and 3) Ospho before 4) prime/paint.
Old Mar 20, 2020 | 11:03 AM
old87yota's Avatar
I am sure Slacker's setup is overkill. He has a fiberglass business making repair panels for our trucks (Toyota Fiberglass), and probably has many tools I can only dream about having.
Old Mar 20, 2020 | 01:59 PM
slacker's Avatar
yeah .. I do own a Toyota Restoration shop , and build fiberglass for Toyotas .. I have plasma cutters , sand blasters and air tools that all like dry air .. That was basically the point I was trying to make , any blaster should do the job , but it is important to have dry air .
my air dryer is 1500 bucks , you certainly don't need that , but you can pick up a desiccant filter , which will dry it as well .
Old Mar 20, 2020 | 03:28 PM
Punjab's Avatar
On the other end of the spectrum, and once you have your compressor setup; this video can give you a cheap DIY blast gun idea.
Old Apr 11, 2020 | 04:58 AM
faber's Avatar
Re:
Thanks all!
mattk
Mar 17, 2020 05:10 PM
ev13wt
Nov 5, 2019 06:31 AM
YotaSyclone
May 27, 2019 02:07 PM
gillesdetrail
260
Mar 26, 2017 04:20 PM
Ricer-X
Jan 19, 2008 06:49 PM
