Pre 84 Trucks 1st gen pickups
Offenhauser and Weber Carb install help
Old Apr 15, 2019 | 06:04 PM
Austin Parkhurst's Avatar
Hello all, I just received my offenhauser intake manifold and weber 38 carb from LCE, along with the plug kit and egr block off kit and would like a few tips/advice. I have the stock carb off so far. I'm not sure which vacuum lines to remove. Do I just scrap them all except for the distributor? There's so many it's overwhelming. Do I use all the manifold plugs? Any advice to ease with the install will be greatly appreciated. Thanks! BTW it's an 82 4x4 pickup.
Old Apr 16, 2019 | 04:44 AM
Lons81's Avatar
The dizzy and the brake booster will need their vacuum lines. For reference for the desmog process, look in the Stickies above, good guide.
Old Apr 16, 2019 | 12:25 PM
medicmoose's Avatar
^ What he said. I did the desmog process by following the posts from Kawazx636 and am running the same carb and intake that you are. It's pretty straight forward.
Triple
Nov 19, 2016 06:21 PM
trevorthetrekker
Sep 10, 2014 01:05 AM
Not Far From Par
Apr 16, 2013 04:39 PM
ncpaladin
May 7, 2012 08:49 PM
