PDA
View Full Version : 84-85 Trucks & 4Runners
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Help - Lift reduction with hy-steer
  2. It seems my 88 4x4 V6 needs rebuilt
  3. 1986+ Rear Brakes Fit on 1985?
  4. 22re ecu
  5. 22re Knock Sensor
  6. Any Experience with extended shackles??
  7. Need some help finding where this hose goea
  8. Oil pressure sensor wire
  9. Moving front axle forward
  10. Aisin 1985 22r carb question
  11. Tail light lenses. 84 SR5, Exr
  12. Oil pump didn’t prime
  13. Anyone know what this six relay harness was for?
  14. 84 Pickup lost all power beyond the under hood fuse box
  15. Will they fit? 88 Truck body parts fit 84 Truck
  16. Seat Belts
  17. 1985 4runner oil leaks /timing chain advice?
  18. 1985 Toyota Pickup Electrical Issues - Seeking Advice Symptoms Listed In Thread
  19. Interior Panels
  20. Holley Sniper fuel injection
  21. 85 sr5 22re keeps studder/ stalls out
  22. 1985 4Runner Front Driveshaft Options
  23. 85 Ext Cab 2wd, 22re issues
  24. 84 extra cab rear cabin plastic replacement
  25. 2wd parts vs 4wd parts
  26. 85 4runner 22re to 3.4 swap
  27. Transmission ?? what is compatible??
  28. Rear Brakes Locking up HELP!
  29. Break peddle goes to floor
  30. Break peddle goes to floor
  31. Odd misfire at WOT
  32. Tailgate hinge pin
  33. Drive Shaft Orientation
  34. Where does this hose go and what is it for?
  35. Project daily driver 85 4runner
  36. Wont Idle
  37. Cluster swap question
  38. Bucket seats
  39. Rough Country 3 inch lift for 1984 4runner
  40. OE Grille Emblem for 85 4Runner Anyone?
  41. 85 4runner 22re issues low power
  42. Sway Bars
  43. 84-85 vent window
  44. IFS Hub Swap Question
  45. 22re swap
  46. Lce pro distributor install
  47. 1986 4 runner Speedo and blower fan stopped same day.
  48. Where Does This Guard/Bracket Go????
  49. 1985 1 ton A4D transmission issues
  50. What hoses are these, leaking fuel
  51. battery deaded
  52. Ham Radio
  53. bent fuel line off pump hanger
  54. Front drive shaft 4x4
  55. 22RE wont turn over when ~32 degrees or below and idle surges when warm
  56. Hard Brake Line Replacement
  57. parking lights come on by themselves
  58. 22r has no power
  59. Aluminum chunks in oil pan! :soap:
  60. Hood bolts
  61. 1984 toyota pickup build
  62. Throw out bearing issue
  63. Intermittent wiper question
  64. 1984 22R distributor cap question
  65. No crank no start
  66. Urgent Help Removing Spare Tire
  67. Replacing right steering knuckle arm on 84 RWD pickup, other possible issues?
  68. Camshaft
  69. 85 4 runner running bad
  70. Center console heater advice and parts (willing to buy parts)
  71. Axle identification
  72. (?) Noob question: High beams on 1984 Toyota Truck?
  73. 85 4runner noises and shaking
  74. Ok stupid newbie tech question.
  75. New exhaust system
  76. Replacing ALL belts
  77. 85 toyota pickup efi 4x4 has no power
  78. What's it worth
  79. third auxiliary accelerator pump diaphragm this year.
  80. Cylinder 3 is leaking???
  81. What is causing a 7.5 amp to blow
  82. Which wire for aftermarket tach?
  83. Weber Tuning Problems
  84. Fuel line issues??????
  85. '85 Toyota 22r won't start after Weber install
  86. Transmission issue, shifter pops out of 1st.
  87. first post and maybe some random Noob questions.
  88. New Engine...oil leaking
  89. What is this in my Axle?
  90. Auto to Manual Trans?
  91. 22r heater hose connections
  92. Goodyear Wrangler Radial Tires for Off-Road Use?
  93. 96 lt1 conversion
  94. 22r carb question, replacement carb has an extra part?
  95. Starter Relay Wiring?
  96. Pinion nut
  97. Toyota Knuckle Differences
  98. 22re cam
  99. Clutch is soft after cylinder replacement
  100. 85 toyota pickup timing issues
  101. 84 22R engine being swapped ot with 85 22R
  102. LSPV [Load sensing proportioning valve] Interchangeability
  103. Exploding (not) transfer case flange nut
  104. 85 pickup save or part out???
  105. Igniter part no. for 1985 T4R 22re motor
  106. Cam Lobe Ground Down
  107. 85 lower gearing
  108. 85 4runner calipers or not? - help ID!
  109. Newbie '84 Xtra cab with Flippac
  110. 1984 4Runner Transmission Swap
  111. Need help
  112. Toyota Dolphin Rear axle swap / HELP!!!
  113. 84 22r rebuild 7 miles
  114. 1985 4runner not getting fuel after jumping wrong terminals
  115. 85 4runna misses
  116. Vacuum sticker pics needed, please!
  117. Fuse Box Wiring Harness ID
  118. Bucket Seat interchange
  119. Unknown popping
  120. Noticed something funny on lifters. Need advice.
  121. too many error codes
  122. 1994, Engine died going up hill, now won't run...
  123. 3rd gen pickup rear springs on 85 4runner
  124. Power window switches
  125. Running horrible
  126. 85 moonroof
  127. Interchange for 88 Hilux SR5 Instrument Cluster
  128. SFA question
  129. sudden loss of spark
  130. Really odd issue with carb or spark issue
  131. 84' 2JZ 4Runner Build
  132. Drive Train
  133. 85 4runner Push Pull Steering advice
  134. Hey all you high altitude Weber guys with a 32/36
  135. Dash Protection
  136. Hi - new guy just trying to nail down vibration - videos included!
  137. I'm missing this part?
  138. xtra cab rear panel cargo nets
  139. 85 22re pickup runs rough cold and wont hot start
  140. Please help me find a home for these hoses
  141. Weber 32/36 throttle linkage
  142. Intake questions
  143. After market gauge backlight wiring
  144. Water pump & timing chain cover gasket sealant
  145. 1st gen 4runner strange problems-newbie-
  146. Webers and HAC High Altitude Compensators
  147. Interesting Radiator Leak
  148. 85 4runner 22RE first start after sitting 5-6? years..blue smoke
  149. 87 turbo 22re timing chain looks good
  150. 22ret turbo size???
  151. My head questions
  152. Question about my lift
  153. Vacuum line size?
  154. Question for anyone with a swing out tire carrier and Jerry cans
  155. 85 4runner gas tank: clean or replace?
  156. Help with 85 - vibration while driving
  157. Lspv help!
  158. Steering Column u-joints
  159. Stripped distributor adjustment bolt
  160. Anyone know what this plate is for
  161. Wiring
  162. Engine Idle issue 93 4Runner
  163. automatic transmission fluid filler tube gasket?
  164. 22R carb adjustment
  165. oil level
  166. 1985 Toyota 4runner, idles low and dies randomly.
  167. Transfer case removal.
  168. Using A Topless 4Runner as a Pickup
  169. Problem with new head gasket
  170. Window Swap
  171. Putting AC on a NON ac truck
  172. Hose under thermostat housing
  173. 84 pickup low brake pedal
  174. no head lights 1988 4 runner sealbeam has power
  175. 1985 Toyota Pickup: Should I buy it.
  176. Fuel pump whines at ON & doesn't shut off, circuit opening relay AFM harness
  177. 1984 4runner 22r lost all accessory power
  178. What year is my engine?
  179. Valve lapping
  180. Ready to pull my engine, advice needed
  181. Toyota Bed
  182. 85 EFI Auto 2WD 22RE Crank No Start Also Compression Low Dry Higher Wet
  183. Hub stud Torque specs needed ?
  184. Coolant hose part number
  185. 1984 4x4 pickup suspension HELP
  186. 85 crossmember
  187. Clutch knocking after replacement
  188. To upgrade or not to upgrade
  189. 85 4runner won't start!
  190. Aftermarket Tachometer Wiring
  191. Chrome grille
  192. Can you still buy new interior screws?
  193. Another Start and Die.
  194. FREE Factory Service Manual 84 4R/Truck
  195. 1985 Toyota Pickup 22re AFM flapper noise
  196. Carbon pile after starting
  197. FJ Cruiser Seats in and 85 4runner?
  198. Help me get my truck on the road please!!!
  199. What wheels and tires for my 1985 4runner build
  200. Can't beleive this is happening. New engine and timing cover cracked...help please
  201. Looking For Smittybilt Bars 85 Pickup
  202. Clutch issues and 4x4
  203. 84 pickup tranny leak? brake leak?
  204. 22re brake booster, will it hold pressure?
  205. Need help with ignition timing
  206. 1985 buying advice, should I buy this?
  207. Oil leak after timing chain replacement
  208. A/C dash switch repurposed
  209. Radio out
  210. Wiring for the backup lights and the 4wd Light
  211. 1985 Resto-Major Mod.
  212. Another TPS thread
  213. Speedo help
  214. Where do these connectors go?
  215. New to group 85 4runner straight axle efi
  216. Braking in the rain.
  217. Timing
  218. problems after front axle rebuild
  219. New Carper - 85 4Runner - Best Fit?
  220. Looking for stock radio for 84 truck
  221. Rough shifting and bad mileage.
  222. 84/85 Dash warning lights
  223. 84 22r not getting fuel
  224. 85 4Runner Will Not Start
  225. won't start
  226. Interior colors
  227. coolant squirting out bottom of intake manifold
  228. HELP!!! Racking my brain on rear-end swap!
  229. 1988 4Runner pulling hard to right
  230. 1984 Toy front receiver hitch
  231. VIN Decoder
  232. Transmission fill plug?
  233. Replacement U-Bolts
  234. How did you remove or bypass your load sensor
  235. Removed bed to install stuff
  236. 22re automatic vs 5 speed
  237. Let's play guess this part :)
  238. My new 85, beater build
  239. battery and brake light on dash
  240. where to get 1984 VSV replacement
  241. 22r exploded dizzy rotor - now won't time
  242. Replaced clutch master and slave now I have transmission noise
  243. Front shock removal
  244. Bad Cold, Good Hot - Woes in TPS
  245. 1985 tailgate decal
  246. Is this the right pitman arm for my Pickup?
  247. Please help!!!!😩 85 22r 106k running rough, black smoke
  248. Need Smog help!
  249. My new 85
  250. 1985 22r bogs down on acceleration
