85 4runner calipers or not? - help ID!
Old Aug 6, 2018 | 06:26 PM
SheepishLion89's Avatar
Hi,
Recently acquired my 85 4runner. PO said he changed the pads a couple of years ago but didn't know much about them when I asked. Anyways, I'm in the process of upgrading but wanted to see if the current calipers are 86+ v6 or just standard ones. Anyone know how to ID? Do I need to pull them out? Here are some pics.
Old Aug 6, 2018 | 06:38 PM
Additional note. The truck is a 85 4runner 4 cylinder 22RE.
Old Aug 6, 2018 | 08:46 PM
thefishguy77's Avatar
Hey man welcome!
You need to keep it in one thread. Only way to get help really.
You need to search first of stuff like this.
http://lmgtfy.com/?q=How+to+ID+85+4r...s+yotatech.com
Seriously welcome but keep it in one thread. Add to your signature everything you know about your truck. Engine, trans, lift, tire size, gears, etc.
Seriously put us in front of you rig.
Old Aug 7, 2018 | 03:15 AM
arlindsay1992's Avatar
86+ 4 cylinder calipers aren't really an upgrade over your SFA calipers. They would allow use of vented rotors from an FJ60 but that's it. The upgrade comes with 88+ V6 calipers (V6's were introduced in 1988) used in conjunction with FJ60 rotors (vented but bolt on when used with any IFS calipers), the 1 inch bore master cylinder, and dual diaphragm booster.
Doesn't look like you have the V6 calipers. The V6 calipers have big fins or gussets to help with cooling or strength. They also have 4 equal size pistons.
Old Aug 7, 2018 | 06:59 AM
SENOR NOODLES's Avatar
where the rotor passes through the caliper, it would have enough clearance for a wider rotor (ifs rotor). that caliper does not seem to have the. which would make it a 79-85 caliper. and nothing to do with anything related too any v6 caliper.
Old Aug 7, 2018 | 07:47 AM
Originally Posted by thefishguy77
Hey man welcome!
Point taken. Thanks! I'll update signature and consolidate
Old Aug 7, 2018 | 07:49 AM
@SENOR NOODLES and @arlindsay1992, thanks for the posts! Will try to hunt down some calipers then. Currently, the rear axle is disasslembled and waiting for parts for rear disc brake conversion. I'll start a thread with pics of the build process to keep it in one place. Appreciate your help!
moroza
Jun 19, 2012 01:28 PM
4Peanut
25
Jun 11, 2011 10:11 AM
myyota
Apr 6, 2010 03:56 PM
arielb1
18
Dec 25, 2004 06:47 PM
schlopecki
11
Jul 14, 2004 07:33 AM
