22re Knock Sensor
Old Mar 16, 2019 | 03:56 AM
Lono&theGremlin's Avatar
22re Knock Sensor
85 PU 22re: Check engine light comes on at 2k rpm. Pulled code 12... knock sensor needs to be replaced. My question is, does the sensor thread through the block into the oil jacket? or does it thread only part way into the block? I am wondering if I need to drain my oil first to replace it.
Thanks
Old Mar 18, 2019 | 03:04 PM
jakey poo's Avatar
No need to drain the oil. I would first pull the sensor and make sure the threads are nice and clean on both the sensor and the block. I had the same symptoms, took a battery terminal brush to all the threads re-installed and it hasn't come back.
dbd6604
Oct 23, 2015 07:16 PM
big1000
Jan 18, 2013 04:13 PM
jodynich
Sep 28, 2009 08:03 AM
Michigan Mud Farmer
Feb 8, 2008 12:58 PM
tlake
Jan 30, 2008 08:53 AM
