PDA
View Full Version : 84-85 Trucks & 4Runners
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 3rd long box fit 4th gen pickup?
  2. 85 22RE High HC at CA smog.
  3. Weber problems
  4. And then she just died....
  5. 1985 4Runner. No start
  6. Help Diagnose Drivetrain Noise?
  7. Metal timing chain guides
  8. 2wd to 4wd body parts questions.
  9. 85 pickup 22r timing chain out of alignment.
  10. tps
  11. frame plugs
  12. 85 Extra Cab AC install
  13. 22r 85 issues
  14. Parts from other models
  15. Diesel 2.4 2WD What's That Under the Alternator ?
  16. Axle ratios
  17. Heater core hose from Intake Bottom Plate - OK?
  18. New clutch for 83/84 truck
  19. Shifting trouble
  20. 85 Toyota pickup 22r battery not staying charged
  21. Need some help
  22. 85 Runner Timing Issue
  23. New wheels/tires for my 85
  24. Vibrations and jumpyness
  25. Door hinge help
  26. 85 strange oil burning
  27. 1st Gen 4Runner: Clutch Releasing Super Late
  28. Set pin on spider cross pin question
  29. A few question on my 85 4runner
  30. My 92 2nd Gen
  31. '84 2wd pickup, hole of some sorts in tranny?
  32. Wiring harness help
  33. 1st Gen 4Runner - Rocker Moulding (Plastic Chrome) - How is it attached?
  34. 22re timing chain metal guides?
  35. My 85
  36. Efi to carb.
  37. Vacuum Lines Incorrectly Routed
  38. 1990 Pickup 2wd- What is this bolt?
  39. Knuckle Alignment Help
  40. Snorkel
  41. Unknown suspension
  42. upgraded seats
  43. Suspension questions.
  44. 85 Runner
  45. SR5 gauge problems
  46. 22RE idle and timing adjustment confusion....
  47. OME ARB 2.5 HD lift installed
  48. front u bolt flip size... diminsions plz!!!
  49. When and how far to rebuild 22R
  50. What's worse, wheels with less backspacing or wheel spacers?
  51. `22RE got wet and won't run right now
  52. Help with signals
  53. 1987 Toyota 4runner
  54. in cab winch controls?
  55. '84 4x4 losing power on inclines
  56. Hub damage under bearing races OK?
  57. manual locking hub clutch size?
  58. Is there a way to ID a year on 8" diff?
  59. front calipers wont disengage
  60. Help w/ identifying stock vs. aftermarket suspension part
  61. axle spline confusion
  62. It just won't give up!
  63. Heater Core hoses location
  64. Cat Removal?
  65. Sons truck
  66. 22r seized distributor
  67. 84 Pickup No dash lights, no headlights, no accessories Help
  68. Drag link orientation
  69. Ran compression test, now getting a code 12 (knock sensor)
  70. Question front floorboard repair?
  71. Brake issue after sitting for long period
  72. Soft suspension suggestions
  73. Torque specs?
  74. 85 4Runner NEW 22RE break in please help!!!
  75. chrome grilles
  76. 1984 Tojo Extra Cab 22r Carb
  77. Trouble starting after sitting overnight or at least 8 hours.
  78. tight valves
  79. Anyone ever dealt with constant power running to taillights and running lights?
  80. 1985 22re fuelpump
  81. WTB 85 Runner EFI ECU
  82. 85 RE won't start
  83. Lock-Rite locker for my 85 ExtraCab with 87 rear end
  84. Electric fuel pump?!
  85. Front seat buckles?
  86. 1985 intake manifold modification.
  87. drift truck
  88. W56 Interchangeability
  89. Rebuilding 85'
  90. no power untill 2500rpm
  91. Truck won't turn or crank
  92. 85 22r carb stumbling
  93. Cheap 2" lift idea(HELP)
  94. Rebuilt trans (G52) Noise
  95. My heater isn't hot enough.
  96. New guy with an '85 2wd
  97. Horn repair in 85 ExtraCab
  98. Trail gear shackle angle
  99. 84 vs 85 exhaust system compatibility
  100. '84 22R wiring question
  101. 1985 Toyota 2Lt upgrade and performance suggestions
  102. 2 Week old gas causes performance problems
  103. Caster, camber adjustments on 86 pickup
  104. Missing hub pieces in outer space
  105. Front Axle Torque spec question. Need help
  106. 85 22re starter does not turn sometimes
  107. 84 vacuum advance 22r-e in may 85 4runner
  108. 1993 4runner headlight swap
  109. 1985 4runner having some problems...
  110. 1985 4runner rear headrest problem
  111. leaky leaky help meee!!!
  112. Rocker Arm Assemebly Trouble- '84 22R
  113. 84pu to 88 4runner tranny swap/rebuild?? questions
  114. Tuming
  115. Bad Vibrations
  116. 1984 Xtra Cab Build Up Questions And Some Pics!
  117. OME Springs.
  118. A few qustions to you guys that have been in wrecks
  119. Just a few rebuild questions.
  120. Knock Sensor or oil pressure switch
  121. Shackle lift 85 pickup
  122. Ride Quality mods. Zuk vs. Shackles vs. 63s
  123. Brake Light Issue
  124. 85 4runner 22re 5 speed
  125. Need Help!!
  126. Problem with pro comp drop drag link
  127. Help!! High Idle after Head Gasket Job.
  128. Strange oil leak
  129. help? Want to do a strip down restore
  130. best shocks
  131. Rear end Sag ???
  132. REdo Seats??
  133. 85 4Runner Worries......
  134. Help identify wheels
  135. Truck Leans to the Right (Driver Side)
  136. Kayline soft top
  137. 1985 Carb Rebuild - broken power valve threads
  138. Diagnosing Engine Knock and Other Sounds
  139. Replacement bulb holders for Instrument Gauges
  140. Flex Plate Woes 85 4runner
  141. 85 yota pickup standard reg cab 4x4
  142. New LED light bar on my truck
  143. Eliminating sliding rear window
  144. 1985 Carbureted 22r A/C bracket part number
  145. Got another 1985 4runner
  146. 1984 22r mystery noise (video link)
  147. What's this?
  148. 85 22re ?
  149. 84 1/2 4Runner top
  150. 84 1/2 4Runner top
  151. AC compressor front seal replacmenet?
  152. pinion bearing?
  153. Replacement birfield?
  154. Where to buy knuckle one piece retaining ring?
  155. Gasket inside valve cover?
  156. No compression on 3&4 1985 22R
  157. Valve Cover Gasket ?
  158. What Sealant is recommended?
  159. Timing chain Cover too tall?!?!
  160. Distance vertically between oil pan and highest part of axle housing?
  161. Pain recommedations
  162. AC Belt Needed??
  163. Delayed overdrive
  164. pcv blow by questions
  165. mystery leak yay
  166. Coolant in oil and vise versa
  167. Cold start issues
  168. Fuel Pump Mounting Bracket Woes
  169. Truck Dies when Engaging Clutch
  170. My 4Runner has newer model brakes?
  171. Anyone know the values of todays 85 4x4 pickup
  172. 1984 toyota pickup not starting right
  173. 1984 toyota pickup not starting right
  174. Head gasket replacement woes
  175. Frozen Longfield and Longfield vs Marfield vs RCV
  176. Guess what I broke 😂
  177. Identifying brake calipers
  178. replacing cam
  179. 22r Fast Idle not working
  180. 84 22r hose attachment help needed
  181. 22re no compression
  182. 22R idle is surging with AC on
  183. Ordering wheels and need help!
  184. Power steering pump rebuild
  185. Knocking sound
  186. Bench Seat?
  187. 84 22r crankshaft pulley problem
  188. Power Steering Parts
  189. High idle with the A/C off
  190. 2 Questions 85 4Runner - 1st about A/C, 2nd about Header
  191. Oil Plug Gasket
  192. information needed on one of a kind decals
  193. 22r ingnitor/coil
  194. Oil pump scoring
  195. Oil Level Mystery
  196. Mystery hose
  197. 86 F350 a good donor?
  198. 85 pickup, no hazards or horn.
  199. Omg loan me 13k someone :)
  200. Disc conversion help!
  201. Do 1st gen 4Runners and shortbed single cabs share a frame?
  202. 84 22r Heater Hose route after desmog
  203. something new to do with a second gen truck(i think)
  204. 4runner tire carrier?
  205. gearing confusion
  206. No crank/low power issue
  207. Uggghhh
  208. '84 exhaust header: advice please
  209. Timing issue
  210. Motorweek review '85 4runner
  211. How do you know if its a Power Antenna?
  212. 22R Engine Advice Please
  213. New 84 Toyota pickup
  214. VSS or Speedometer?
  215. Original parts help!
  216. Fuel Tank Pickup Tube Assembly
  217. Coolant going into reservoir--engine getting hot
  218. OME Suspension Install and Tips
  219. 84 Toyota weber flooding
  220. Radiator replacement for 1985 automatic 4runner
  221. Question on hi-steer
  222. 3 cores?
  223. Bottle Jack Location in Xtracab
  224. IFS Steering box for hy-steer.. manual/power?
  225. Adding Power Door Locks
  226. When is a good time to rebuild?
  227. Trail gear ifs mount install help
  228. 85 Speedo drive question
  229. 84 sr5 22r rebuild about to start
  230. 1985 4Runner 22RE Auto Shift Problem
  231. 1985 4Runner 22RE Auto Shift Problem
  232. Fuel Gauge Indicator Jumps
  233. 4.88 question
  234. 85 front axle hub dowel pins?
  235. 85 22re gas removal and such! HELP!
  236. Repair kit for my new 84 toyota truck
  237. 1985 22r pickup, no spark but engine cranks
  238. 1985 22re a/c install help
  239. How to fix Steering linkage
  240. just bought an 84 toyota 4+4 pickup and engine is knocking
  241. 22 re high rpm missfire!
  242. In cab noise level
  243. another 22re noise :/
  244. mysterioius drive shaft problem
  245. OEM sunroof or aftermarket.
  246. Tacoma or IFS brake upgrade
  247. New engine in my 85 4x4 ExtraCab
  248. Steering Box of 85 Diesel Pickup compared to 85 Gas Pickup
  249. fuel gauge wont read full but still functions
  250. Door size
