Knuckle Alignment Help
Old Mar 1, 2016 | 12:39 PM
seanski1969's Avatar
I an currently working on refreshing my 85 SR5 ExtraCab. I need some help with the knuckle bearing alignment. Currently have third member out and completely cleaned and don't have the toyota special tool to measure the thickness of the shims in the knuckle alignment. Anyone in the Sacramento area who has the tool or is willing to help me please email me.
I have owned this truck since college in 92 and am currently going through and refreshing the entire truck. Will post pics as I go through but upgrades are as follows.
New Windshield w/ Australian Rubber Gasket (too be installed soon) Sand and Repair Rust surrounding windshield
Tacoma brake booster, 4runner V6 Brake Master Cylinder and Calipers, Land Cruiser Rotors. LowRange Offroad Backing Plate Eliminators
Repair Rust in Firewall and Cab of truck
Energy Suspension Complete Bushing Kit
Convert AC system to R134
Repair Wiring Issues for Fuel Injectors
Repaint Entire Frame and Undercarriage as I work though truck Will paint truck this summer hopefully if I can find a place to do it and maybe some help.
Thanks
Sean
Old Mar 3, 2016 | 02:48 PM
osv's Avatar
osv
if you kept the shim distribution separated like it was when it came from the factory, you shouldn't need to re-measure anything, just put it back together the same way that you took it apart.
not sure what wiring issues you are looking at for the injectors, but these trucks are notorious for having rusty flaking wire junctions in the middle of the engine harness, where the wires from the injectors were spliced, apparently after they left the factory.
the actual wiring is therefore slightly different from what's shown in the harness wiring diagram.
if you were going to do something like replace the injector connectors, be sure and look at the splices.
rocket
Feb 28, 2016 07:49 PM
jeepfreak4648
Feb 26, 2016 05:39 AM
