axle spline confusion
Old Feb 4, 2016 | 03:52 AM
furlong24's Avatar
Not sure if this is a simple question, or even posted in the right spot.
But, my question is about the switch from the stock 85 Toyota 3rd to the high pinion, I know the high pinion will fit into my housing, but does it use the same axles? or is it of a different spline count?
Old Feb 4, 2016 | 06:15 AM
MudHippy's Avatar
The entire diff is also a direct bolt-in to all front and rear axles that use an 8" diff.
http://home.4x4wire.com/erik/diffs/
Meaning...no other changes/modifications required. So your 30 spline axles will work.
Old Feb 4, 2016 | 02:33 PM
furlong24's Avatar
thank you for the Knowledge, I checked the link you gave but it says the 8" is a 27 spline? so if the HP is 30 then it wouldn't work
Old Feb 4, 2016 | 02:55 PM
MudHippy's Avatar
Right...27 spline pinion. 30 spline axles. So the HP will work.
I have like 6000 posts...you can trust me on this.
Old Feb 5, 2016 | 04:00 AM
furlong24's Avatar
Not doubting just trying to learn, how does the axle differ from the pinion?
Old Feb 5, 2016 | 05:37 AM
MudHippy's Avatar
They're different parts entirely. The pinion I'm refering to is the gear connected to the driveshaft which turns the ring gear. Together they're called the ring & pinion or final drive gears. They spin the differential, which spins the axle(shafts), which spin the wheels.
The term axle can mean the entire front/rear axle assembly(housing, 3rd, axleshafts, brakes). Or it can mean just a singular axleshaft.
The term pinion can also refer to the other pinion gears in the differential. As in a 2 pinion or 4 pinion differential. Which doesn't mean the 3rd has 2 or 4 ring & pinion gears. They are also different parts entirely.
It's all about context.
b_stone81
Dec 27, 2015 08:42 PM
Ifoundyoda
Dec 6, 2015 02:29 PM
jordanhere123
Nov 17, 2015 08:09 AM
Steven.m.paulk
Nov 13, 2015 08:57 PM
