- 22r to 22re Swap, wiring help.
- Vibration that I cant figure out
- 95 4runner auto skips 3rd gear
- 85 22rec code 12 help
- black plastic cab side trim?
- weird starting issues
- LED light bar
- Timing issue.. What distributor do I need?
- Mystery problem
- cosmetic help locating parts
- 84 toyota pickup question please help!
- Misplaced bolts for plate on rear of cylinder head
- What did I break on the carb?
- 87 4runner 22ret body on a 85 4runner
- Cranking but not starting
- 85 4x4 diesel
- throttle body heater help
- electrical problem?
- OME IFS to SAS
- Weber carb question
- 32/36 re-jet question
- Crank pulley issues. Grooves and leaking
- Mutt truck?
- Best Tool Box for 1985 with Bobbed Bed
- loping idle 1989 3.0 please help
- Rebuilt 22r smoking?
- '85 truck wont turn over?
- thinking about parting out my 85 toyota 4x4 pickup
- 85 22re dies on warm start
- Truck Starts But has No Power
- Lets talk propane
- Leak after timing chain replacement help
- Metal Timing Chain Guide? (photo)
- Has anybody ever converted an sas to an ifs?
- Trans mount and fluids
- 84 pitaman arm
- Soon to have '85 toyota pickup ext cab
- Difficulty shifting into 1st and reverse
- Very Frustrating, no spark.
- Uneven idle +-10 rpm at 750 22re Auto
- throttle cable 21 inch
- SR5 Cluster Swap Speedometer Problem. Video inside.
- cylinder head rear plate..22re
- 3 truck rebuild thread
- stock 84 steering box adjustment
- gear oil capacity??
- DIY Snorkel. Cheap an Easy
- 92 pickup into 85 4runner
- 85 4wd power issues
- Window trim question
- Anyone with a tach?
- Rebuilt engine wont start
- 84xcab recon mission
- Rear U-Joint Replacement
- '84 22R Pickup A/C Cooling Unit Removal
- 84 and 88 toyota pickup
- iac disconnected
- 2'' body lift installed now doesnt stay in reverse or 2nd gear
- Windshield wipers stuck ON
- 22re Won't start until Ether
- Strange shifting issues after valve cover and intake manifold gasket replacement
- TPS Sensor Question
- 17" wheel on 1985 Pickup need tire for DD
- Timing Light on 22re pickup, good for checking miss fire?
- Wandering Steering, caster/front spring related?
- 84-85 Pickup and 4 Runner Headlight upgrade
- Anyone know where I can find a wiring diagram?
- 85 power windows
- Video - Noise = pilot bearing?
- Need some guidance on lifts/ tire size
- Window seals...
- Rear lift spring hanger bolts
- What's this part called?
- 4Runner top on a SR5 Truck?
- Rear axle removal.
- 84 pickup rancho steering stablizer
- No power please help!
- 1985 toy header issuse
- installing stereo head unit
- 85' pickup major drivetrain malfunction
- Why the solid front axle?
- 84 pickup wont start
- loose drag link
- 4Runner Fuel Tank Protector on 2WD Pickup?
- NO SPARK...1984 Toyota 4runner
- DUI Distributor 22r Install Details?
- '85 Hilux engine identification help
- '85 Toyota Pickup
- 1989 22re clicking timing chain, replacement?
- 1985 22RE FI Gas Tank Fuel Sender orientation Please
- 22re driving me crazy
- Thinking of going from SFA to IFS
- 1985 Toyota 4 runner springs should I get
- Connecting EFI and fuel system on 85 4x4
- manual hub restore
- funky high idle issue ( '84, 22R )
- black plastic or rubber cab plugs
- 84 toy P/U carb'd no spark.. bought new parts.. still no spark
- Help rebuilt 22re not running right now
- What is that thing under the hood?
- Back in SW CO!
- Timing off on 22re
- 1985 toyota celica gts question`
- rebuilt 22re sluggish until 3k
- noise in 4x4
- Please help URGENT "Truck Light LED headlight issue"
- 1985 toyota pickup 22R idling down
- 1985 pickup std. cab leaking water in cab
- '85 cardan question
- 85' 22re rough idle and Ox code.
- 89 22re rebuilt NEED vacuum line diagram
- 85 sr5 22re cold start prob
- Looking for VSV for my A/C to fit my 1986 Toyota Pickup
- welding rocker panel 84 4runner
- 1985 22re Open Loop
- Decking block with t-cover
- 1985 pickup 22re auto trans problem
- 84 22re tps
- 1985 22re recent rebuild low power a/t
- 1985 Toyota Pickup Front Leaf spring help?
- axle rebuild kit...is this crap?
- Will 86 pickup 22RE A/C system fit in my 86 Pickup 22R???
- 85 xtra cab skid plate
- Transmission Dipstick on 1984 SR5
- Failed Smog Visual California. Help!
- 85 yota running like CRAP! sputtering wants to die.
- solid axle help
- head gasket size questions
- '84 Head/Exhaust Manifold Questions
- Dying at idle after replacing motor mounts
- Where to get clutch fork boot.
- Help 93 4runner 3.0 stumbles at idle and jerks while driving
- Troubleshooting Clutch master and slave problem
- white/ gray smoke
- 85 toyota pickup battery draw down
- Custom flatbed tail lights brake lights ?
- 85 4Runner Front Lift Springs Suggestions
- no side veiw mirrors...?
- Blown head gasket
- The problem im having is spark timing
- Strange Stalling Issue
- 22r running hot
- 84 toyota lift?
- Putting together a 5 speed case, can I use sealant instead of gasket
- 84 differential fill plug size??
- Fried wires. Truck won't fire
- heat...vent...bi level..defrost
- Rear fender rust: What to do about it? welds are rusting through to outer body
- 1985 toyota 22r 4wd 136000 mileis age
- lifting a 85 2wd questions
- Seals
- Pulley wobble
- blower motor sounds like freight train...
- truck doesn't roll well?
- HELP plugs on 1 &4 black
- 1986 Toy PU - SUPERCAB
- White/ blue smoke @ high RPM
- 22r carb issues
- Replacing the icm in my 84toy truck
- Broken timing chain guide?
- Charging issue
- loud ticking sound from engine
- $3,000 worth of upgrades on stock '84 Pickup
- Truck has no power
- Best cheap semi wheelng lift 3inch
- Water in oil and water in coolant system.
- 1985 Turbo diesel 4x4..….how rare?
- Ball Joints Puking Grease, 2WD
- Looking for a shock
- 85 22r strange timing issue
- Keep blowing my 80a fuse
- Ways of lifting my yota
- 84 pickup sr5 22RE. what transmission
- 85 Toyota Dead on Road.
- Bilstein shocks unavailable for 85 4runner??
- 1985 4runner stumbles upon acceleration
- LCE performance intake
- 1984 Catalytic Converter issue
- Are exhaust manifolds interchangeable from early 22r to late 22r
- Heater trouble
- 85 exhaust manifold on 84 head?
- Vibration issue
- 1986 22r runing like crap
- 84 truck accelerator cable help!!
- Bizarre oil leak / Any input?
- 86 4runner wont start after blown radiator?
- Need a huge (and quick) 22RE favor...
- My 95 4runner restoration project
- Brake booster?
- 1985 22RE missing terribly - out of nowhere
- transmission noise
- more weber carb ?s
- 22re fueling problem?
- weber Trans-Dapt adapter from Summit
- Newbie here needing AM Exaust manifolds ect.
- Manual transmission drain plug crush washer
- 85 4Runner TJ Zuk Mod question...
- ruf and stock gearbox
- weber carb 1 piece adapter help
- Smog Legal headers
- Lift question
- 1984 pickup exhaust system
- SR5 gauge cluster swap help!
- Ivan ironman edition toyota
- downside to a gm alternator considering the jaguar alt
- Interior dimensions...
- head job pic dump
- Small Rust Hole in Frame
- 85 Runner RUF clearance question
- 88 4runner 22re Stalling
- My new rig. 1985 Runner.
- 85 22re brake booster/issue causing surging idle
- compression tests
- 84 P/U seat cover recommendation
- Rear wheel fender well skirts - which ones where?
- 85 diesel injection pump question
- Floppy turn signal question
- Are stock center diffs open or locked in 4wd?
- performance camshaft for 22r or propane?
- What 5spd fits
- Will my header work??
- Pro Comp Series 51 wheels on an '85 4x4?
- Frozen Tachometer?
- 84 2wd rear diff - drive shaft play
- Quick question???
- 1985 EFI Vacuum Hose Help
- toyota misfire
- weber carburetor problems
- 87 Toy pickup rough idle whem warm
- power steering pump rubs coolant hose underneath
- 1985 toyota sr5 pickup, 22re engine will not turn over when cold out
- what setup for flex?
- panel swaps
- New Radiator, Overheating While Bleeding System
- Best locker for front of the '85
- which rear springs?
- 1984 Toyota pickup Horn wiring
- 85 22re Stiffner braket
- Starter not disengaging after engine swap
- Gasket between engine and Intake Manifold
- 22r 32/36 dfev
- Swapping efi for carb with good reason
- Help ID some unusual parts on 84 2wd
- rebuilt 22r not starting
- 84 4x4 stock carb leak
- Crossmember and transfer case mount not lining up
- Need Help W/ Pickup Catalytic Conveter
- Timing chain question
- 1984 diesel 2.4 manual transmission fluid
