Quick question???
Old Jan 7, 2014 | 04:33 PM
Arnieg727's Avatar
Quick question???
Own a later model 22re but I noticed today that my cold start fuel line (coldstartfuelline?) next to the efi was leaking gas. Quick fix? New gasket? New part what?
I'm new to the yoda life any thing helps thanks not sure if it's fuel line I just know that it has to do with cold start
Old Jan 7, 2014 | 05:26 PM
lobukbuild's Avatar
pictures would help. does it have a banjo fitting? banjos have soft washer like seals that can be replaced or tightened. if its an actual line it would probably need to be replaced.
Old Jan 7, 2014 | 05:42 PM
HighLux's Avatar
Get a gasket. Its a level 1 out of 10.
Old Jan 7, 2014 | 06:52 PM
Arnieg727's Avatar
I'll put a pic on tomorrow for a better look at it.
Old Jan 8, 2014 | 08:31 AM
Arnieg727's Avatar
This is it. Not my picture tho
Old Jan 8, 2014 | 02:05 PM
HighLux's Avatar
Lets try this again. Get a gasket. Fix it.
Old Jan 8, 2014 | 02:24 PM
RAD4Runner's Avatar
Let's try it again - LOL!
Is the steel line leaking or is it leaking from the fitting, or where the gasket it?
Old Jan 8, 2014 | 02:28 PM
HighLux's Avatar
Ok Forest. Here we go.
Get the gasket. Get 2 copper washers.
Any time you remove a banjo bolt....you always replace the copper washers.
Thus...by replacing the gasket...you will have solved both problems.
jasonty
41
Dec 23, 2018 01:00 PM
thefishguy77
Aug 9, 2015 04:15 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
icentropy
Jul 14, 2015 10:23 AM
