Crossmember and transfer case mount not lining up
Old Dec 10, 2013 | 10:16 PM
hitsua's Avatar
I just replaced the W56 in my 85 runner, and now the hole in the middle of the crossmember will not line up with the hole on the bottom on the transfer case mount. The only thing I can think of it is to replace the mount, and/or get a new crossmember. Any thoughts?
Old Dec 11, 2013 | 03:06 PM
Stevesk88's Avatar
was it a direct swap? Like you had a 56 before and swapped with another? Is your xmember going the right direction? (dumb question i know)...Are you using the tcase mount that mounts to the xmember from the old set up or from the one you got your new trans from? Might check to see that they are the same. Sometimes they are different.
Old Dec 11, 2013 | 03:09 PM
cman1's Avatar
might be backwards?
Old Dec 11, 2013 | 03:14 PM
wyoming9's Avatar
Red face
If it is the same transmission model
Backwards or your trying to mount the transfer case after bolting the cross member to the frame.
Things move around get things lined up get all the bolts in before you tighten anything.
Old Dec 11, 2013 | 04:50 PM
hitsua's Avatar
We managed to get it to line up. Went forward and backwards a few times once everything was put back together and the transfer case dropped into the hole.
Tykiller1994
Aug 10, 2015 07:49 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
89hilux1
Jul 19, 2015 01:32 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
crashburnoveride
Jul 10, 2015 06:39 AM
