PDA
View Full Version : 84-85 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 85 4runner EFI Hesitation
  2. 22r timing issue
  3. 85 4Runner with a Rough Country 3" suspension lift
  4. some serious negative camber??
  5. e brake stuck
  6. Bobbed my bed (PICS)
  7. 85 Engine swap or rebuild?
  8. please HELP!85 22re injectors not firing
  9. manuel or auto trans
  10. Revived a 1987 Pick-up
  11. BAD NEWS BEARS, Rebuild NO GOOD so far
  12. Belt issue
  13. bad mileage = motor running bad?
  14. 85 22re no power to injectors
  15. clutch problems.......
  16. Could this be stock 85 4runner paint scheme?
  17. clutch or pinion?
  18. Head Gasket?? And a bunch of codes
  19. question on 5 lug tranny options
  20. '85 4Runner Heater Hose Kit... where to find?
  21. Front axle binding, possibly birf?
  22. towing question
  23. can i use 95 4runner mc instead of an fj80 mc?
  24. How to install trailgear ifs steering box mount
  25. The valve noise that won't GO AWAY!
  26. Broke something on my motor during rebuild
  27. Need some help with my engine.
  28. Al's 7m swap (finally)
  29. creeper T-case shifter
  30. Turbo convertion oil setup
  31. 85' 4runner horrible sounds when backing up
  32. toyota pickup diesel
  33. Will this fit
  34. Bought a FPR and have some questions
  35. Aftermarket cam settings?
  36. 85EFI fuel filter change, no start
  37. Yn60 85 4runner diff gears - plz help
  38. 91 22RE into 85 22RE truck
  39. Fresh 22re Rebuild - Coolant Leak
  40. 85 4 Runner
  41. 4WD 4H and 4L speeds
  42. Let See Your Bull Push Bar
  43. 1st Gen 4Runner tailgate to pickup tailgate conversion
  44. Lift question/problem
  45. 3.0 header owners, I just picked up some used Downey headers, got a few questions
  46. LCE underdrive pulley... belt part numbers?
  47. 84 4runner draglink loose
  48. cab swap or wiring swap
  49. Steering Box Slippage + rig pic
  50. 85 22re vacum diagram
  51. 22re antifreeze in oil
  52. Alternator crapped out
  53. front axle seal bad? can i still drive?
  54. 85 Superlift Questions
  55. 89 4runner gas mileage???
  56. electrical problem
  57. 22RE - SR5 Idiot Light ?
  58. Throttle body
  59. "Hey Corey, where is my thread?"
  60. 22re - Disabling Fuel Injectors
  61. 2nd gen brake upgrade for 1st gen 4runner
  62. 4.7 transfer case or 5.29 rear which is better choice for trail rig
  63. running on 2 cylinders
  64. Red Leader
  65. 22re lost of power?
  66. 2nd Gen 4runner steering packages...anyone buy these?
  67. 85 fi 4wd missing
  68. anyone use a aftermarket coil on a 22r?
  69. Gears/33in tires
  70. whats your idle like with a 261 lift cam
  71. 85 RE 4runner
  72. Auto to 5spd - front driveshaft problem. PLEASE HELP!!!
  73. Too doubler or not to double that is the question?
  74. G 52 rebuild kit Which one
  75. 3" of hard lift... how does high-steer fit?
  76. Best Muffler?
  77. seats and interior color
  78. Running lights come on with brake depressed
  79. Ring and pinion
  80. header help
  81. EFI to Carburetor NEED HELP!!
  82. differential question
  83. Power Steering Idler Pulley
  84. altimeter and inclinometer troubles...:(
  85. Where to buy a 2984 22r fuel pickup???
  86. I'm in a pickle! T-case issue
  87. ? on motor
  88. 22r to 22re converted to carb
  89. metal rod below tail gate
  90. engine knock sensor
  91. 84 4runner plastic trim panels
  92. Flatbed for Toyota shortbed
  93. Blinker Voltage Drop? Horn radio connection?
  94. 92 3vze missing
  95. Wont start goin crazy!!!
  96. Tryn to get back into the yota hobby
  97. adding power windows, relay wiring?
  98. Ebay 22re rebuild video
  99. What gas tanks fit my Long Bed 84 2wd?
  100. 85 No drive train whats it worth ??
  101. safety neutral switch?
  102. stupid noob... another rear window thread
  103. Lets see your Colorado rigs and pics of wheeling in Colorado
  104. Quick Question: Spring Hanger Relocation
  105. master cylinder
  106. 22RE Runs Rough
  107. 85 power window gremlin!!
  108. Orange 4Runner?
  109. 22r running rich
  110. Manual to auto
  111. sweet noise starting at 55 on when accelerating
  112. ABS Rear Axle on 84 4Runner?
  113. 22re swap help
  114. Where do THESE plug into???
  115. 84-85 factory service manuel
  116. Bad misfire after tune up
  117. No Electrical Power
  118. Trail Gear HD Tcase Mounts
  119. yoder519 back in a yota!!!
  120. My new 85 SR5
  121. Hard pull when braking
  122. first ever REBUILD
  123. power steering gone, higher engine temps, charge bat light, and pbrake light
  124. '84 22r carb? fuel pump?
  125. 22RE check engine light, running way too rich
  126. Headlights upgrade. HID's??
  127. 22RE throttle body (?)
  128. Rear Window Won't Work
  129. new driveshaft?
  130. Transmission Oil Recommendation - W56
  131. Some snow wheeling pics
  132. Heater not working
  133. It is a runner!
  134. RUF for 1-2" only?
  135. Very Odd power loss problem
  136. catalytic converter
  137. welding v6 third member
  138. Emissions Removal Questions
  139. Xmas heater core R&R. Dickens is spinning in his grave!
  140. '88 4Runner w/Fast Idle
  141. 85-22re-engine harness green round connector mystery
  142. not the clutch, its the tranny :(
  143. Power Steering
  144. 22r to 20r swap problems
  145. Made it to Big Bear... Barely...
  146. will 2wd fenders bolt on a 4wd truck?
  147. Lowest miles on '84-84 4Runner
  148. 22r heating up
  149. bumper problems
  150. power window motor upgrades?
  151. Where to source full OME kit?
  152. Carburetor Problems
  153. Hey look! I can see the ground!
  154. black sut in clutch master cylinder
  155. 54mm nut and that big socket
  156. A Little thanksgiving Fun
  157. Cut fan shroud in half?
  158. Ford Shock Tower's installed
  159. Timing chain broke, bent valves certain?
  160. Oil out around the distributor shaft?
  161. bleeding brakes
  162. lost spark
  163. 22re to 22r/propane Question
  164. cleaning throttle body and other intake parts
  165. Gear set questions
  166. im ready to start my swap but got question
  167. just can't win, broken bolt
  168. Can you check these oils before I purchase?
  169. Rust
  170. ignition coil/module differences ?
  171. Heater core FSM page no#
  172. Locking Front Hubs
  173. 84 Truck 22r no power when key is on
  174. burning oil through rings or valve seals?
  175. A little weekend wheeling
  176. Choke Issues
  177. detonation, retard or advance
  178. drop oil pan on 84 w/o lift
  179. Supercharger for 2.4 diesel
  180. 85 4runner dlx
  181. Alternator Ground
  182. Weight of removable hard top?
  183. Stupid E-locker question
  184. 84 Timing Chain question
  185. 84 pickup missing at highway speeds.
  186. new to site and need help
  187. dual timing row ? oppnions
  188. 84 Toy Truck no power
  189. How well does your 22R rev/go?
  190. 85 4Runner igniter/module swap EFI
  191. Rear electrical window switch??
  192. Rear Window Wiper HELP
  193. Need help getting rings to seat!
  194. Can't get leaf spring on???????
  195. 1985 LN61 4runner rear brakes
  196. What engine is actually in my 84?
  197. Wanted: Used Header and Exhaust
  198. This stage seems to be done!!
  199. Installing Weber 34
  200. what shocks to run on 85
  201. Part no. - 4runner rear window channel
  202. 22R overheating
  203. 1985 4Runner New to Me
  204. How do your 22r's do starting in the cold?
  205. Need Help with '85 4Runner problems -- Semi NewB
  206. Flat spot/Rough Running 84 22R
  207. 22RE - Adujusted Valve Lash, Now Stutters & Dies
  208. driveshafts??????
  209. Wheel bearing rotating preload?
  210. Mysterious heating problem 84 22r can I get a little help..
  211. 85 4Runner 22RE help
  212. Got bored after da turky took some pics with updates
  213. 4runner manual harness or pickup auto harness
  214. 1985 Pickup Heater/Vent control broke: Fix??
  215. Burning Oil
  216. Anyone have shifter council pics mine is gone
  217. Weber carb electric choke to manual conversion?
  218. Front anti wrap link
  219. start and run problem
  220. head gasket
  221. 22re intake mani on 22r with carb???
  222. Inner/outer bearing preload?
  223. to rebuild or to re-ring that is the ???
  224. 85 Toy electrical/fuel problem
  225. Starter wiring hookup problem?
  226. 84 22r carb problem
  227. Disassembly of birfield?
  228. Auto Tranmission Control Unit
  229. Question about Downey 3" Lift Springs
  230. Trunnion Bearing Cap Shims - How thick?
  231. remove cylinder head w/o removing timing cover?
  232. ’84, 22r truck,,,Coolant filling up the cab
  233. hesitant/hard start
  234. Clicking transfer case
  235. New Shocks/front suspension parts
  236. tell me what you think
  237. 22re Oil Galley Plugs
  238. running water pump w/o center bolt?
  239. Custom flat beds pictures wanted
  240. advanced timing issue
  241. Brake problems
  242. Removing clips from hub, suggestions
  243. Need a Motor!?!?!?
  244. Need help diagnosing this???
  245. 85 4 Runner AUTO Tranny
  246. Shock sensor?
  247. Anyone got 16" wheels
  248. 4runner tailgate 1st gen
  249. can this be removed/replaced?
  250. how to remove brake line?
