RUF for 1-2" only?
Old Dec 30, 2009 | 11:23 AM
BerHntr's Avatar
RUF for 1-2" only?
i got a set of lift shackles this weekend from pullapart off an 88 runner and put them on the rear of my truck. they only netted about 1.5" of lift which works for me. no money for gearing or larger tires right now. for the front i was wondering if i could use some of an extra set of rear leaf springs as basically an AAL type setup? i could stand to go a little more in the front because of my heavy heavy bumper.
Old Dec 30, 2009 | 11:40 AM
4Crawler's Avatar
That is about all the lift you will see from the stock rears up front:
- http://www.4crawler.com/4x4/4R_suspe...l#Update-part3
However, if you still have stock steering and u-bolts, you'll have trouble adding leaves due to the clearance with the steering and spring plate.
Old Jan 6, 2010 | 11:29 PM
4x4YOTA's Avatar
I got aboout 1.5" lift out of my RUF (stock 83 rear leaf + aal) pack and an extra 1" from my boomerang shackle so I ended up with 2.5" of lift could prolly be lower if I used a stock rear leaf pack
2.5" lift on 37s
Old Jan 6, 2010 | 11:49 PM
MuddfreaksOffroad's Avatar
dont you rub alot??? looks like those tires are realllly close to the fenders sitting on flat ground? but nice truck tho man!
Old Jan 7, 2010 | 12:30 AM
4x4YOTA's Avatar
she only rubs on the springs my axle is move about 1.5" froward so that helps also flattend the pinch weld and bump stops help
Originally Posted by 4x4YOTA
Old Jan 7, 2010 | 12:41 AM
4x4YOTA's Avatar
I mainly run my 32s but I can clear 37s with only 2.5" of lift
justdifferentials
14
Jun 11, 2017 08:36 PM
live4soccer7
May 11, 2016 06:52 PM
I8URSVT
Jan 15, 2016 07:25 PM
Toys4parts
Sep 26, 2015 01:56 PM
I8URSVT
Sep 3, 2015 11:42 AM
