hesitant/hard start
Old Nov 17, 2009 | 04:58 PM
wannagetrdone's Avatar
hesitant/hard start
Ok this is a new 22r engine in the truck. The truck is an 85 sr5 4x4 pickup. The problem is when tryin to crank the engine it will turn over fine for a few revolutions and when it tries to start it ll kick back like it high in time. The battery and starter is new and check out fine. Engine runs and is not outta time but cant figure out whats causing this. Any ideas?
Old Nov 17, 2009 | 05:03 PM
Kiroshu's Avatar
Fuel? Spark? Low fuel pressure, faulty fuel pump, fuel filter clogged. Distributor cracked, corroded, rotor button corroded, plug wires faulty, spark plugs faulty. Vaccum leak, main intake air hose leaking. 22r or 22re? Airfilter dirty. If 22r carb out of adjustment. Timing? Idle speed correct?
Old Nov 17, 2009 | 05:13 PM
INFINITY's Avatar
timing.....timing....timing....................... .................
Old Nov 17, 2009 | 06:40 PM
timing is fine. plugs wires cap and rotor are new and idle is to specs . used three cans of wd-40 and no vacuum leaks so far
Old Nov 18, 2009 | 08:31 PM
turner01's Avatar
Are you running a EGR system? maybe check that...
Old Nov 19, 2009 | 05:06 AM
84toyota4x4extcab's Avatar
id say its your carb
Old Nov 19, 2009 | 07:05 AM
ISLANDER 80 CRUSHER's Avatar
try some carb cleaner, if it gets better after a couple of squirts. Then it is your carb. Another suggestion is that make sure your battery has enough charge.
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
