Yn60 85 4runner diff gears - plz help
Old Feb 3, 2010 | 01:04 AM
da_blowfly's Avatar
Unhappy Yn60 85 4runner diff gears - plz help
Hi, I have a 4 Cyl 3Y '85 4runner solid front diff, I have recently found out that the rear diff is just about had it, unsure on what ratio it is but my placard plate say's it has a G142 which I've found a site that say's a G142 means it's a 4.88 ratio diff but I'm unsure so just wondering if the rear diff ratio has to be the same as the front ratio.
Any help would be appreciated!!
Old Feb 3, 2010 | 01:12 AM
Truckfiend's Avatar
This should help you.
http://home.4x4wire.com/erik/diffs/
Old Feb 3, 2010 | 01:28 AM
da_blowfly's Avatar
hi thanks for your reply, ive looked at that site but it doesnt seem to show my diff there my diff only seems to have 2 ribs not 3...
Old Feb 3, 2010 | 01:34 AM
Truckfiend's Avatar
Try this one then. Lots of good info.
http://www.off-road.com/trucks4x4/ar....jsp?id=274535
Old Feb 3, 2010 | 01:58 AM
Truckfiend's Avatar
As far as I know the G142 is a 4.88 As well as G144. The G142 is a 2 pinion and the G144 is a 4 pinion. I`m a little suprised you have an 85 with a G142 code. To my knowledge ONLY 92 to 95 automatic 4runners came with 4.88`s, I`m not 100% on that though.
Old Feb 3, 2010 | 01:59 AM
da_blowfly's Avatar
i have actually took my time time to read that first site u gave me as before i was in the process off draining rear diff oil only to find a few nice size bits off metal in diff and only was reading bits and pieces but now i understand will check out asap but have also found out that both diffs have to match so all i need to do is find out wat gears thanks for the help been awsome
Old Feb 3, 2010 | 02:07 AM
da_blowfly's Avatar
yer well in the trans/axle code its g52 g142 and it a 3y with solid front diff and a 5 speed when i read one off those sites u gave me before to my memory said something like that and thats first one says that the centre diff housing has 3 ribs mine if im looking properly have a big flat bit at top and bottom and 2 ribs each side this is why im stumped only thing i can think off is that the whole rear end is out of something else
cause at the same time ive realized that where the hand brake cables go across into the diff they jam up againts the leaf springs and not letting it work properly
Old Feb 3, 2010 | 02:27 AM
da_blowfly's Avatar
well just did the spin test and it is 4 & 3/4 to aevery 2 wpins off the tyre so if im correct that means it would be a 4.88 ratio am i correct?
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
