Oil out around the distributor shaft?
Old Dec 17, 2009 | 07:25 PM
84YotaBuck's Avatar
Have a oil leak somewhere on the drivers side that I can't seem to find. Pulled the power steering pump off and set it off to the side so I could get a better view and ran the engine after cleaning things off and for the life of me I can't see any leak. It appears to be dripping onto the alternator belt/alternator and getting flung everywhere when it is leaking, can oil creep up the distributor shaft and drip out there? There appears to be some sort of ring/gasket at the top of the shaft, don't know if it's supposed to be hard like mine, or a soft o-ring. Any input? Thanks.
Old Dec 17, 2009 | 07:48 PM
myyota's Avatar
There is an o ring on the distributor that can go bad and cause an oil leak, you have to remove the complete distributor to change the o ring.
Old Dec 17, 2009 | 08:04 PM
84YotaBuck's Avatar
yeah, already have it out, my o-ring is just so hard it feels more like a nylon ring. Did some Bing'n, I think I'll just pick up a new o-ring and saw off the old one Only $3.50 for a new one and appears to be a somewhat common spot for a leak.
Old Dec 17, 2009 | 08:24 PM
myyota's Avatar
The o rings become hard from the engine heat over the years and start to leak.
Old Dec 17, 2009 | 10:51 PM
live4soccer7's Avatar
might have to check mine. wouldn't doubt if I was leaking from there also.
Old Dec 18, 2009 | 11:23 AM
84YotaBuck's Avatar
Picked one up from the stealership a few mins. ago. Only 3.75, gonna go replace it now and hope that fixes my leak.
cars-guy
Aug 16, 2020 06:59 AM
Eggslinger
Jun 8, 2019 03:32 PM
raptor510
Feb 17, 2017 07:11 AM
A2theK
Jan 10, 2016 10:18 AM
msane99
Jul 11, 2015 08:08 PM
