Cut fan shroud in half?
Old Dec 18, 2009 | 11:26 AM
84YotaBuck's Avatar
Anyone ever cut one in half horizontally to make it easier to remove? With it stock you have to take the clutch fan off which can be a pain, would make everything easier if you could take the shroud out first, then you'd have more room to get the clutch fan off, or alternator out. I'm thinking, cut in half horizontally, you'd have 2 bolts holding each half on. If you did it vertically, the way the bolts are the center may flex out, but horizontally I would think it would be allright.
Old Dec 18, 2009 | 11:31 AM
TOYOTA 1's Avatar
iirc the 3rd gens are already like that from the factory, not sure though.
Old Dec 18, 2009 | 12:11 PM
4Crawler's Avatar
Just pull the lower part of the shroud off:
- http://www.4crawler.com/4x4/ForSale/...ToyotaRadiator
Old Dec 18, 2009 | 12:45 PM
84YotaBuck's Avatar
would love to, but mine is all one piece. Just finished cutting it in half, looks like it'll work like a champ!
young buck
18
Aug 27, 2018 02:40 PM
upongame619
Aug 1, 2015 12:12 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
Edionne13
Jul 9, 2015 01:59 PM
zd92655
Jul 5, 2015 04:25 PM
